Aluminum round tubing
Does anyone have a good detail showing welded round tubing. I am need a corner detail that shows a 90 degree connection and one showing a perpendicular connection. If anyone has any leads on this I would appreciate it.
So you are interested in the fittings at the corner and the tee?
Correct, the corners will be mitred, so that is easy. The tee connection will be welded. The top tube will be notched and the perpendicular tube will also be notched so the fit into each other.
2D details?
What are you fabricating?
Yes 2D. It is a frame for a portable platform. Its is about 8 feet long and 4 feet wide. It will have hinges in the middle and fold up. So it is really two frames.
And you are using tube not pipe? Why aren't you using tube fittings? It would go much easier/quicker.
1" Alumminum round tube 6061 T6 with .035" walls
