fabriciorby
ViewPort Handling
fabriciorby
Hello,
I've searched about this issue but I couldn't find anything useful to me.
I'm trying to make something like this:
I have a square inside my Model and a square ViewPort inside my Layout. I need to make the viewport to zoom to a point until the square inside my Model fits the ViewPort.
I have no idea how to work with ViewPorts using lisp :/
I can upload a screenshot if it's too confusing
Thank you (:
Share this post
Link to post
nestly
Zoom > Object will zoom the "square" in model to the largest dimensions that will fit inside the viewport
Doh... I overlooked that you're apparently looking for a lisp solution.
Share this post
Link to post
fabriciorby
How to select the viewport using lisp? Because what I really want to do is, for example, I have 10 squares in the drawing so a copy 10 layouts. For each Layout I need to get one of these squares and zoom.
Share this post
Link to post
fabriciorby
And if I have 80 squares, for example, I would need to setvar 'ctab every time and it would take a long time. I was thinking about using the Model square points to get the zoom. I tried but I can't understand how VIEWPORT'S DXF works.
I was thinking about (ssget "x" '((1 . "MVIEW")(410 . LAYOUTNAME))) and then changing their zoom properties.
Share this post
Link to post
Tharwat
Is this what you are after ?
Don't select too much Closed LWpolylines .
(defun c:Test (/ *error* o l i n ss in sn v ln)
 ;;--- Tharwat 15. June. 2013 ---;;
 (setq doc (vla-get-activedocument (setq o (vlax-get-acad-object))))
 (defun *error* (x)
   (vla-put-LayoutCreateViewport
     (vla-get-display (vla-get-preferences o))
     l
   (princ "\n*Cancel*")
 (setq l (vla-get-LayoutCreateViewport
       i 1
       n "Square-"
 (if (not l)
     :vlax-true
 (if (setq ss (ssget '((0 . "LWPOLYLINE")
                       (-4 . "<AND")
                       (70 . 1)
                       (90 . 4)
                       (-4 . "AND>")
   (repeat (setq in (sslength ss))
     (setq sn (ssname ss (setq in (1- in))))
     (vla-getboundingbox
       (setq v (vlax-ename->vla-object sn))
       'j
       'k
     (while (member (setq ln (strcat n (itoa i))) (layoutlist))
       (setq ln (strcat n (itoa (setq i (1+ i)))))
     (vla-add (vla-get-layouts (vla-get-activedocument o)) ln)
     (setvar 'ctab ln)
     (vla-put-mspace doc :vlax-true)
     (vla-zoomWindow
       o
       j
       k
     (vla-put-mspace doc :vlax-false)
 (setvar 'ctab "Model")
(vl-load-com)
Share this post
Link to post
BlackBox
From within an activated viewport of the same scale:
(command "._zoom" "window" "_end" pause "_end" pause)
Share this post
Link to post
fabriciorby
Wow, thank you Tharwat, your code can bring me a lot of ideas. (: (I'm so bad at VisualLisping)
But is there a way of doing this without 'ctab? Only changing DXF values?
You created an layout using VisuaLisp, is there a way to copy an layout with visual lisp? I mean, instead of using (command "layout" "copy")?
You create a new viewport everytime, but, is there a way to select an existing one? If not, is there a way to change the viewport dimension while creating it?
Share this post
Link to post
fabriciorby
Hm, this can be very helpful. I just need to get the viewport selected, because I'm going to have 2 viewports at the same layout ):
Share this post
Link to post
BlackBox
I use it as a simple routine, so that I manually double click within the desired veiwport, and invoke as if a normal command:
(defun c:ZW ()
Share this post
Link to post
Tharwat
You're welcome and happy to hear that .
What's wrong with the 'ctab ? actually we should use it in the code to port at the layout's deck to enter the viewport to zoom for
a specific LWpolyline ( square ) .
That way is not applicable in this case due to the sequence naming of layouts .
Share this post
Link to post
fabriciorby
Yes, but I have written a code to make it applicabble (with help from the forum, sometime ago). Let me post it.
[color=RED]([/color][color=BLUE]setq[/color] layouts [color=RED]([/color][color=BLUE]vla-get-layouts[/color] [color=RED]([/color][color=BLUE]vla-get-activedocument[/color] [color=RED]([/color][color=BLUE]vlax-get-acad-object[/color][color=RED]))))[/color]
[color=#990099];; Temporarily rename layouts to reduce risk of duplication when renumbering[/color]
[color=RED]([/color][color=BLUE]vlax-for[/color] layout layouts
	[color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]/=[/color] [color=#a52a2a]"MODEL"[/color] [color=RED]([/color][color=BLUE]strcase[/color] [color=RED]([/color][color=BLUE]vla-get-name[/color] layout[color=RED])))[/color]
	[color=RED]([/color][color=BLUE]vla-put-name[/color] layout [color=RED]([/color][color=BLUE]vla-get-handle[/color] layout[color=RED]))[/color]
	[color=RED])[/color]
[color=RED]([/color][color=BLUE]setq[/color] sfilter [color=RED]([/color][color=BLUE]list[/color][color=RED]([/color][color=BLUE]cons[/color] [color=#009900]8[/color] [color=#a52a2a]"NUM_FOLHA"[/color][color=RED])([/color][color=BLUE]cons[/color] [color=#009900]0[/color] [color=#a52a2a]"TEXT"[/color][color=RED])([/color][color=BLUE]cons[/color] [color=#009900]410[/color] [color=#a52a2a]"MODEL"[/color][color=RED])))[/color]
[color=RED]([/color][color=BLUE]setq[/color] s [color=RED]([/color][color=BLUE]ssget[/color] [color=#a52a2a]"x"[/color] sfilter[color=RED]))[/color][color=#990099];; gets how many square numbering texts it has in the model[/color]
	[color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]not[/color] [color=RED]([/color][color=BLUE]=[/color] [color=#a52a2a]"MODEL"[/color] [color=RED]([/color][color=BLUE]strcase[/color] [color=RED]([/color][color=BLUE]vla-get-name[/color] layout[color=RED]))))[/color]
		[color=RED]([/color][color=BLUE]progn[/color]
			[color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]<[/color] [color=RED]([/color][color=BLUE]setq[/color] order [color=RED]([/color][color=BLUE]vla-get-taborder[/color] layout[color=RED]))[/color] [color=#009900]10[/color][color=RED])[/color]
				[color=RED]([/color][color=BLUE]setq[/color] layname[color=RED]([/color][color=BLUE]strcat[/color] [color=#a52a2a]"0"[/color] [color=RED]([/color][color=BLUE]itoa[/color] order[color=RED])))[/color]
				[color=RED]([/color][color=BLUE]setq[/color] layname[color=RED]([/color][color=BLUE]itoa[/color] order[color=RED]))[/color]
And, your routine creates a new viewport everytime, but, is there a way to select an existing one? If not, is there a way to change the viewport dimension while creating it?
Edited by fabriciorby
editing code
Share this post
Link to post
Tharwat
You are renaming the layouts with their handles' strings and not copying them as you have asked before . ;)
You can by the use of the 'ctab system variable and with global selection set for the same layout space (cons 410 (getvar 'ctab)) and then you should iterate through the selection set if it holds more than one viewport ans so on .
Share this post
Link to post
fabriciorby
Yes, because I'm copying it manually. The first one is: 01, so the next ones are going to be 01 (2), 01 (3), 01 (4), ... and that's why I rename it, first with it's handles and then with taborder.
edit: Oh, I'm sorry, I think I forgot to quote you and we got a misunderstanding here ):
Share this post
Link to post
fabriciorby
(defun c:ZW ()
I see, I was thinking about making it automatic, without double clicking. ):
Share this post
Link to post
Tharwat
As far as I know there is not a function that does that same like the layout command call with the use of copy option as well , but if you are interested in copying the settings of one layout to another , you can use the function vla-copyfrom .
Share this post
Link to post
fabriciorby
Thank you, Tharwat. I'm going to try this function. (:
I'm going to study your code, maybe I'll need to ressurect this topic soon hehehe
Share this post
Link to post
BlackBox
That would potentially require a persistent, per-Document, per-PViewport association storage mechanism that is dependent on an initial setup... Hardly automatic from the big picture, when we're talking about the simple task of picking two points. Just saying.
Share this post
Link to post
fabriciorby
I don't know if I correctly understood you but, yes I'm going to use this lisp in templates already created (that are dwg and not dwt).
All the squares are going to have a layer with its respective number, this number is gong to have its own layer too. What I'm doing is to get all squares from the layer and then getting their points to (ssget "wp") and get those numbers filtering by layer. Those numbers are going to be the layout name, so it's going to be "01", "02", "03"...
I think it's going to work (:
Share this post
Link to post
fabriciorby
copy thru layouts ?
kruuger
Actually, I'm not looking for this haha. Thank you kruuger, it's an interesting lisp by the way (:
Share this post
Link to post
