Guest kruuger Posted June 18, 2013 Posted June 18, 2013 I don't know if I correctly understood you but, yes I'm going to use this lisp in templates already created (that are dwg and not dwt).All the squares are going to have a layer with its respective number, this number is gong to have its own layer too. What I'm doing is to get all squares from the layer and then getting their points to (ssget "wp") and get those numbers filtering by layer. Those numbers are going to be the layout name, so it's going to be "01", "02", "03"... I think it's going to work (: maybe you can make a block (border) with attribute (layout name) and then generate layouts and viewports. something like this: http://forum.cad.pl/download/file.php?id=5358&mode=view kruuger Quote
fabriciorby Posted June 21, 2013 Author Posted June 21, 2013 (edited) maybe you can make a block (border) with attribute (layout name) and then generate layouts and viewports.something like this: http://forum.cad.pl/download/file.php?id=5358&mode=view kruuger Looks interesting, but I think I got what I wanted to do, I just got it so the code is still ugly... Thank you guys for all your help (: Edited June 26, 2013 by fabriciorby Quote
