JD Mather Posted June 17, 2013 Posted June 17, 2013 Next he'll be asking JD just to do the assignment for him. ....well if he had stayed around. V-Twin Engine.zip unzip attached. Open the dwg file. Go to Manage tab. Click Load Application. Files of type *.lsp and select Drive.lsp and then Load. Close the dialog box. Type Drive and then hit Enter. Might freeze up your computer for about 5 sec - don't panic, it will come back. Quote
ReMark Posted June 17, 2013 Posted June 17, 2013 I have term paper to write about the industrial revolution. Can I get that by tomorrow morning JD? LoL Quote
neophoible Posted June 17, 2013 Posted June 17, 2013 Can you post every step until the end here, because I finished one with mistakes and sent to the professor and told him that I have some mistakes, I told him that i will fix later. Thanks for your timeThe general answer to this is No. JD was walking you through it and you quit on him. Not smart. If you just want steps through to the end, nestly gave you that early on. If you cannot follow simple instructions or continue past what nestly gave, for example, you cannot dimension, then you are in way over your head on this one. Quote
