esinor Posted June 22, 2013 Share Posted June 22, 2013 (edited) Having difficulty installing AUTOCAD 2012..32bit I am having an error says : Error applying transforms. Verify that the specified transform paths are valid. I am using Windows Vista... Thanks in advance for you help and instructions Edited June 22, 2013 by esinor Quote Link to comment Share on other sites More sharing options...
Organic Posted June 22, 2013 Share Posted June 22, 2013 If you Google the error message, it seems to be a common problem (not jsut for AutoCad although a lot of Windows software). Some people deleted certain AutoCad registry entries (which is a bit risky in my opinion) and it seemed to fix it. While I found the registry keys to delete for 2011 and 2013 I could not find the ones to delete for 2012, although I'm sure if you Google hard enough you could find it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 22, 2013 Share Posted June 22, 2013 I'd recommend upgrading your OS to Win7 first. Quote Link to comment Share on other sites More sharing options...
