Removing unwanted grips in dynamic blocks
kArThIcK hAcKeR
kArThIcK hAcKeR, perhaps you need to explain precisely why you need the behavior you are asking for. The reason I say this, is that, normally, you could simply set up a simple toggle to turn the grips ON/OFF, depending on which editing situation you need. It would pretty much be lightning fast, a couple of quick keystrokes or even just one, depending on how you do it. I do this sort of thing all the time with dimensional units, switching from Metric to Architectural to Decimal (inches) depending on what I need at the moment. However, if your editing, etc, needs them to be the same at the exact same time, then you may just be out of luck.
  • Replies 24
  • kArThIcK hAcKeR
    9
  • feargt
    7
  • nestly
    3
  • steven-g
    3
Posted Images
SOLVED:
Guys, I figured it out.:shock:
There is an optional property for blocks called "Annotative".:oops:
(Sorry, For the late reply guys, i didn't get any notifications of the topic being updated, usually i used to get mails, now i didn't get any mail, so i didn't check the forum:unsure::oops:)
Open Your Block in block-editor and in the properties palette u will be able to see the "Annotative" option, make it "Yes":glare:
Note: (don't select any object inside of the block, then only u will be able to see the main properties of the block)
My Block when Opened:
Properties Palette:
My Block After Changing The Annotative Property To "Yes":
Notice The other grips which were present before, has disappeared. Problem Solved.
(and By the way i accidentally found this out, just today, (i didn't check the posts;)))
Thanks for the help guys.:shock:
We leave it open, in case anyone else spots a better method of doing things.
You don't need to take any action.
Glad we could help. :beer:
