Ugh... I feel so out of it. It's been a year since I've even touched a program, and now I'm doing it while multitasking with sleep deprivation!
I know how you feel - there are some programming tasks that I do very rarely and always find myself having to re-learn everything all over again...
To save you some time in reading up on AutoLISP & Scripts just for this task, you could use my free Script Writer program which will do most of the automation for you.
Instructions:
  • Copy the drawings to be processed to a new temporary folder so that you are working with copies (always recommended when batch processing!).
  • For the 'Script Line', type the following (change the highlighted block names to suit):
_.open *file* (load "DeleteBlocksV1-0.lsp" nil) (if LM:DeleteBlocks (LM:DeleteBlocks (LM:acdoc) '([highlight]"Block1" "Block2" "Block3"[/highlight]))) _.qsave _.close
  • Select the temporary folder of drawings to be processed.
  • Run the Script.
I hope this helps - if you get stuck, just ask.
  • Replies 20
  • resullins
    9
  • ReMark
    6
  • Lee Mac
    5
  • MBSupport
    1
