Huuthanh Posted August 6, 2013 Posted August 6, 2013 Thank Lee! Please show me difference between the two routines! Quote
Lee Mac Posted August 6, 2013 Posted August 6, 2013 Thank Lee! Please show me difference between the two routines! Change your UCS and try each of the two programs - The first will return values in WCS, i.e. the same values will be returned regardless of your UCS settings. The second will return values expressed relative to the active UCS. Quote
dpenney Posted August 25, 2013 Posted August 25, 2013 Change your UCS and try each of the two programs - The first will return values in WCS, i.e. the same values will be returned regardless of your UCS settings. The second will return values expressed relative to the active UCS. Would these also work in paperspace? We can do coordinate dimensions in paperspace as we always work from a set Datum 0,0... This would be great if the N & E lisp worked also. Cheers Quote
Lee Mac Posted August 25, 2013 Posted August 25, 2013 Would these also work in paperspace? Yes, the programs will work in any drawing layout. Quote
