ewibolo Posted September 17, 2013 Share Posted September 17, 2013 Hi again everyone, I was wondering if anyone knows why this is happening? The blue line is the section, the red line on top is the existing ground. Thanks, Edited to add: by this, I mean the blue line doesn't daylight up to existing ground. Thanks again, Ewibolo Quote Link to comment Share on other sites More sharing options...
Organic Posted September 17, 2013 Share Posted September 17, 2013 It is hard to say although I would guess it is a problem with either your assembly and the daylighting rules or, alternatively within your corridor, you are daylighting to the wrong surface. Is the batter line on the right hand side of the section near the benching/guttering, correct or erogenous? It wouldn't surprise me if there is a way with styles that you can show the natural surface that is to be removed as well as the finished daylighted surface and that has been enabled inadvertently. Quote Link to comment Share on other sites More sharing options...
