Crosshair size
How come I am unable to use 100 crosshair size when it comes to using ISOMETRIC snap? When using rectangular snap, the crosshair line stretches across the screen while isometric snap only shows short line? I hope I am clear on my question.
Try this. Make sure your crosshairs is set to 100% in the display tab under options. Then go to the 3D Modeling tab and disable 'Show Z axis in crosshairs'.
Many thanks, Soleary! That solved my problem :)
You're welcome. Glad it helped.
