Hello everyone,
I have some LISP code to hyperlink blocks to a file. However, based on new folder structure my company has started using, I am trying to adjust it.
We have a folder for drawings:
/Project/03_Final/AwesomeCAD.dwg
And within the cad drawing, I am wanting to hyperlink to photos at:
/Project/02_Photos/AwesomeImage.jpg
The way it currently works, the dwg file needs to be at the same location as images.
(setq URL (strcat "\\02_Photos\\" pID "-" sID "_" num0 ".jpg"))
How would I modify this to hyperlink to another folder in the same project location?
Thanks!
Update:
I got it to work using:
(setq URL (strcat (getvar "dwgprefix") "..\\02_Photos\\" pID "-" sID "_" num0 ".jpg"))
However, I need to path to be relative.
Edited by Ohnoto
I do not really understand the request nor the issues you have. Maybe post the code so it may be more clear. Thanks!
I can't post the full code. It was not written by me, but a co-worker, for company purposes, and is pretty long. I was going through it to tweak a bit to what I needed it to do.
Our folder structure here is:
Project Name
  • 01_WIP
  • 02_Photos
  • 03_Final
  • 04_Sent to Client
  • 05_3D Files
When we do send a project to a client, we send the 02_Photos folder and 03_Final folder.
Within our drawing, we have a block that represents where photos were taken from. Our owner is wanting to have these hyperlinked when sending to a client.
When I was stating relative before, I was in the mindset of relative path, like xrefs, where xrefs will stay attached across folders, as long as the folder structure is intact.
We do have it LISP to work, but only when the photos folder is in the same folder as the drawing. I was looking to see if there was a way to keep them connected across folders.
From what I have been researching, it may not be possible dealing with hyperlinks, but I'm hoping someone can prove me wrong.
