Hi All
I have AutoCAD 2012 LT version. I have opened the program, get the loading screen, then the program opens but then closes straight away within about 1 second.
I am on my laptop and away from my usual work location need to complete some work and I do not have my install CD with me.
I reset all settings using the start menu and restarted my computer but still have same problem.
Could anyone help out with this issue?
Greatly appreciated.
Thanks
Emms.
I can suggest one thing but not sure this will be solution for you or not -
Control Panel -> Add or Remove Programs -> Autocad -> Change/Remove
Repair Your Autocad.... I hope this will fix your issue
Edited by satishrajdev
I would recommend trying the REPAIR option first.
What are the specs of your laptop? Does it meet the recommended system specs necessary to run the program?
