  • Replies 26
  • souvik
    9
  • GP_
    6
  • eldon
    5
  • ReMark
    3
Posted Images
If you can't get the lisp to work, the suggestion by steven-g in post #12 is excellent
Could you please tell me process to work with the lisp..
I am afraid that I can't tell you how the lisp works, because I did not use it. I used the method of changing the UCS.
Here is the sample.......
*@*#|^@#* (censored)
"Points with z value labelled"
I thought points with fields.
:danger:
:danger:
:lol: That's the reason why i hold off writing a code for this request.
Nice idea BTW _GP
Thank you, pBe :)
@souvik
Try this code for points and mtexts.
(defun c:TesT (/ cmd p&t L n L1 L2 p_t ep_t :p1 :p2 :p1z )
   (vl-load-com)
   (setq cmd (getvar 'cmdecho))
   (setvar 'cmdecho 0)
   (command "_.undo" "_begin")
   (if
       (and
           (princ "\nSelect points and mtexts to align")
           (setq p&t (ssget '((0 . "POINT,MTEXT"))))
           (setq L (car (entsel "\nSelect the reference line")))
           (= "LINE" (cdr (assoc 0 (entget L))))
           (or oL (setq oL 0.00))
           (setq oL
                    (cond
                        ( (getdist (strcat "\nOffset from the line <" (rtos oL 2 2) ">:  ")) )
                        ( oL )
           (setq L1 (cdr (assoc 10 (entget L))))
           (setq L2 (cdr (assoc 11 (entget L))))
           (setq L1 (list (car L1) (cadr L1)))
           (setq L2 (list (car L2) (cadr L2)))
           (repeat (setq n (sslength p&t))
               (setq p_t (ssname p&t (setq n (1- n))))
               (setq :p1 (cdr (assoc 10 (setq ep_t (entget p_t)))))
               (setq :p1z (last :p1) :p1 (list (car :p1) (cadr :p1)))
               (setq :p2 (LM:ProjectPointToLine :p1 L1 L2))
               (if (not (equal oL 0.0 1e-6)) (setq :p2 (polar :p2 (angle :p2 :p1) oL)))
               (if (= "POINT" (cdr (assoc 0 ep_t)))
                       (setq :p2 (list (car :p2) (cadr :p2) :p1z))
                       (vla-put-Coordinates (vlax-ename->vla-object p_t) (vlax-3d-point :p2))
                       (setq :p2 (polar :p2 (angle :p2 :p1) (* 1.7 (cdr (assoc 40 ep_t)))))
                       (vla-put-InsertionPoint (vlax-ename->vla-object p_t) (vlax-3d-point :p2))
   (setvar 'cmdecho cmd)
   (command "_.undo" "_end")
;; Project Point onto Line  -  Lee Mac
;; Projects pt onto the line defined by p1,p2
(defun LM:ProjectPointToLine ( pt p1 p2 / nm )
   (setq nm (mapcar '- p2 p1)
         p1 (trans p1 0 nm)
         pt (trans pt 0 nm)
   (trans (list (car p1) (cadr p1) (caddr pt)) nm 0)
Edited by GP_
