ymg3 Posted May 15, 2014 Posted May 15, 2014 plecs, Change this line: (getorcreatetablestyle "CadEng") (setq pt (getpoint "\nPlace Table :") tblobj (vla-addtable msp (vlax-3d-point pt) (+ (length lst_blk) 2) [color="red"]4[/color] height width) ) And below the whole code with the changes (not tested): and finally delete this line: also here: (setq j -1 header_lsp (list "NR. CRT." "LISTA PIESE" "GROSIME" "BUC") ) And finally delete the following line or put a semi-colon in front of it: (vla-setblocktablerecordid tblobj row 4 (getobjectid (vla-item blks blk_name)) :vlax-true) (defun c:blkqty5 (/ *adoc *h* *util attlst blk_id blk_len blk_name blks desc en entlst h header_lsp horizmargin height i j total len0 lst_blk msp pt objtblsty partnum row ss str tblobj txtsty width width1 width2 x y) (vl-load-com) (defun txtwidth (val h msp / txt minp maxp) (setq txt (vla-addtext msp val (vlax-3d-point '(0 0 0)) h)) (vla-getboundingbox txt 'minp 'maxp) (vla-erase txt) (- (car (vlax-safearray->list maxp)) (car (vlax-safearray->list minp))) ) (defun getorcreatetablestyle (tbl_name / name namelst objtblsty objtblstydic tablst txtsty) (setq objtblstydic (vla-item (vla-get-dictionaries *adoc) "ACAD_TABLESTYLE")) (foreach itm (vlax-for itm objtblstydic (setq tablst (append tablst (list itm)))) (if (not (vl-catch-all-error-p (setq name (vl-catch-all-apply 'vla-get-name (list itm))))) (setq namelst (append namelst (list name))) ) ) (if (not (vl-position tbl_name namelst)) (vla-addobject objtblstydic tbl_name "AcDbTableStyle") ) (setq objtblsty (vla-item objtblstydic tbl_name) txtsty (variant-value (vla-getvariable *adoc "TextStyle")) ) (mapcar '(lambda (x) (vla-settextstyle objtblsty x txtsty)) (list actitlerow acheaderrow acdatarow)); (vla-setvariable *adoc "CTableStyle" tbl_name) ) (defun getobjectid (obj) (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE")) (vlax-invoke-method *util 'getobjectidstring obj :vlax-false) (vla-get-objectid obj) ) ) (defun quantity (lst / item qty rtn) (while lst (setq item (car lst) qty 1 lst (cdr lst) ) (while (= (cadr item) (cadr (car lst))) (setq qty (1+ qty) lst (cdr lst) ) ) (setq rtn (cons (append item (list qty)) rtn)) ) (reverse rtn) ) (if (setq ss (ssget (list (cons 0 "INSERT")))) (progn (setq i -1 lst_blk nil) (while (setq en (ssname ss (setq i (1+ i)))) (setq entlst (entget en) blk_name (cdr (assoc 2 entlst)) attlst nil ) (while (/= (cdr (assoc 0 entlst)) "SEQEND") (if (= (cdr (assoc 0 entlst)) "ATTRIB") (setq attlst (cons (cdr (assoc 1 entlst)) attlst)) ) (setq entlst (entget (setq en (entnext en)))) ) (setq desc (car attlst) attlst (reverse (cdr attlst)) partnum (strcat (car attlst) " x " (cadr attlst) " - " (cadddr attlst)) lst_blk (cons (list blk_name partnum desc) lst_blk) ) ) (setq lst_blk (vl-sort lst_blk '(lambda (x y) (< (cadr x) (cadr y))))) ;; Here we need to remove duplicate and add qty to lst_blk (setq lst_blk (quantity lst_blk)) (or *h* (setq *h* (* (getvar "dimtxt") (getvar "dimscale")))) (initget 6) (setq h (getreal (strcat "\nText Height <" (rtos *h*) "> :"))) (if h (setq *h* h)(setq h *h*)) (or *adoc (setq *adoc (vla-get-activedocument (vlax-get-acad-object)))) (setq msp (vla-get-modelspace *adoc) *util (vla-get-utility *adoc) blks (vla-get-blocks *adoc) ) (setq horizmargin h width1 (+ horizmargin (txtwidth "NR. CRT." h msp) horizmargin) width2 (+ horizmargin (txtwidth (cadr (car lst_blk)) h msp) horizmargin) width (+ (* (+ width1 width2) 2) (* width2 1.5)) height (* 2 h) ) (getorcreatetablestyle "CadEng") (setq pt (getpoint "\nPlace Table :") tblobj (vla-addtable msp (vlax-3d-point pt) (+ (length lst_blk) 2) 4 height width) ) ;(vla-put-regeneratetablesuppressed tblobj :vlax-true) (vla-setcolumnwidth tblobj 0 width1) (vla-setcolumnwidth tblobj 1 width2) (vla-setcolumnwidth tblobj 2 (* width2 1.5)) (vla-setcolumnwidth tblobj 3 width1) (vla-setcolumnwidth tblobj 4 width2) (vla-put-vertcellmargin tblobj (* 0.75 h)) (vla-put-horzcellmargin tblobj (* 0.75 h)) (mapcar '(lambda (x) (vla-settextheight tblobj x h)) (list actitlerow acheaderrow acdatarow)) (mapcar '(lambda (x) (vla-setalignment tblobj x ) (list actitlerow acheaderrow acdatarow)) (setq j -1 header_lsp (list "NR. CRT." "LISTA PIESE" "GROSIME" "BUC") ) (repeat (length header_lsp) (vla-settext tblobj 1 (setq j (1+ j)) (nth j header_lsp)) ) (setq row 2 i 1) (foreach pt lst_blk (setq blk_name (car pt) j -1 ) (vla-settext tblobj row 0 i) ; ITEM NO. (vla-settext tblobj row 1 (cadr pt)) ; PART NUMBER (vla-settext tblobj row 2 (caddr pt)) ; DESCRIPTION (vla-settext tblobj row 3 (cadddr pt)) ; QTY (vla-setcellalignment tblobj row 1 acmiddleright) (vla-setcellalignment tblobj row 1 acmiddleleft) (vla-setcellalignment tblobj row 2 acmiddleleft) (vla-setcellalignment tblobj row 3 acmiddleright) (vla-setcellalignment tblobj row 3 acmiddlecenter) (setq row (1+ row) i (1+ i)) ) (vla-deleterows tblobj 0 1) ;(vla-put-regeneratetablesuppressed tblobj :vlax-false) (vlax-release-object tblobj) ) ) (princ) ) ymg Quote
claudiokad Posted April 27, 2017 Posted April 27, 2017 hi, please help, autocad 2007 error, Command: blkqty5 Select objects: 1 found Select objects: 1 found, 2 total Select objects: Text Height : Place Table :; error: Automation Error. Invalid input Quote
claudiokad Posted April 27, 2017 Posted April 27, 2017 Hi! I need help, the following code, presents the data in column, I need to present them in lines, example 1! 2! 3! 4! 5 this data line has reference the attributes of a block, follow code, thanks ;;-----------------=={ Count Attribute Values }==-------------;; ;; ;; ;; Counts the number of occurrences of attribute values in a ;; ;; selection of attributed blocks. Displays result in an ;; ;; AutoCAD Table object. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; (defun c:CAV nil (c:CountAttributeValues)) (defun c:CountAttributeValues ( / _Dxf _Assoc++ _SumAttributes ss i alist ) (defun _Dxf ( key alist ) (cdr (assoc key alist))) (defun _Assoc++ ( key alist ) ( (lambda ( pair ) (if pair (subst (list key (1+ (cadr pair))) pair alist) (cons (list key 1) alist) ) ) (assoc key alist) ) ) (defun _SumAttributes ( entity alist ) (while (not (eq "SEQEND" (_dxf 0 (entget (setq entity (entnext entity) ) ) ) ) ) (setq alist (_Assoc++ (_Dxf 1 (reverse (entget entity))) alist)) ) ) (cond ( (not (vlax-method-applicable-p (setq space (vlax-get-property (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) ) (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace) ) ) 'AddTable ) ) (princ "\n** This Version of AutoCAD Does not Support Tables **") ) ( (and (setq ss (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (setq alist (_SumAttributes (ssname ss (setq i (1- i))) alist)) ) (setq pt (getpoint "\n Ponto de Inserção da Tabela: ")) ) (LM:AddTable space (trans pt 1 0) "DESCRIÇÃO DE MEDIDAS" (cons '("Cod.:" "Descrição:" "Qtda.:" "Seq.:" "Largura:" "Altura:" "Esp.:") (vl-sort (mapcar (function (lambda ( pair ) (list (car pair) (itoa (cadr pair))) ) ) alist ) (function (lambda ( a b ) (< (strcase (car a)) (strcase (car b))))) ) ) ) ) ) (princ) ) ;;---------------------=={ Add Table }==----------------------;; ;; ;; ;; Creates a VLA Table Object at the specified point, ;; ;; populated with title and data ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; space - VLA Block Object ;; ;; pt - Insertion Point for Table ;; ;; title - Table title ;; ;; data - List of data to populate the table ;; ;;------------------------------------------------------------;; ;; Returns: VLA Table Object ;; ;;------------------------------------------------------------;; (defun LM:AddTable ( space pt title data / _itemp ) (vl-load-com) (defun _itemp ( collection item ) (if (not (vl-catch-all-error-p (setq item (vl-catch-all-apply 'vla-item (list collection item)) ) ) ) item ) ) ( (lambda ( table ) (vla-put-StyleName table (getvar 'CTABLESTYLE)) (vla-SetText table 0 0 title) ( (lambda ( row ) (mapcar (function (lambda ( rowitem ) (setq row (1+ row)) ( (lambda ( column ) (mapcar (function (lambda ( item ) (vla-SetText table row (setq column (1+ column)) item ) ) ) rowitem ) ) -1 ) ) ) data ) ) 0 ) table ) ( (lambda ( textheight ) (vla-AddTable space (vlax-3D-point pt) (1+ (length data)) (length (car data)) (* 1. textheight) (* textheight (apply 'max (cons (/ (strlen title) (length (car data))) (mapcar 'strlen (apply 'append data)) ) ) ) ) ) (vla-getTextHeight (_itemp (_itemp (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object)) ) "ACAD_TABLESTYLE" ) (getvar 'CTABLESTYLE) ) acDataRow ) ) ) ) (princ) Quote
