soniaest Posted October 23, 2013 Share Posted October 23, 2013 Hello! I'm working in a dynamic block and I think that I've had to mark or unmark some option in the program because since yesterday I can't use as an initial point of any parameter some central points. I mean, when I try to specify the initial point of any parameter (e.g.: rotation) where the four lines converge, the program tells me that the " 2d object is not valid". I hope I've explained myself right... Can you help me to restore anything that I might have changed? Thank you very much! Warp.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 23, 2013 Share Posted October 23, 2013 (edited) WOW I'm impressed, nice block, the problem is it is 3D and the block editor isn't too happy with that, the four lines you mention where not on the working plane so I moved them down to Z=0, if you need them elevated then place your actions first and then move the lines back to where you need them. EDIT --- maybe OSNAPZ will help (I can't test it, it's not available in LT) sorry it's the second DWG I couldn't figure out how to delete the first Warp.dwg Warp.dwg Edited October 23, 2013 by steven-g Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2013 Share Posted October 23, 2013 I thought there was no such thing as a 3D dynamic block? Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 23, 2013 Share Posted October 23, 2013 The content is and can be 3D, it's just the actions that are limited to 2D Quote Link to comment Share on other sites More sharing options...
soniaest Posted October 23, 2013 Author Share Posted October 23, 2013 Thanks a lot!!!! Now it's working perfectly... I still have so much to learn... Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 23, 2013 Share Posted October 23, 2013 You are welcome, we are all learning, I didn't realise before today that 3D blocks could cause an issue this way, it's good to know. Quote Link to comment Share on other sites More sharing options...
