richard3009 Posted November 7, 2013 Posted November 7, 2013 When creating/defining attributes in a block editor, what determines the order they will be displayed in the "Edit Attributes" GUI when working on the drawing. Quote
dbroada Posted November 7, 2013 Posted November 7, 2013 The attributes used to appear in reverse order of picking the ATTDEFs when selecting the block items, but that was when you had to do . Now that you can do that may not be true. You could also WBLOCK the block and the order would be reversed again! It may be something to do with creation time but I've never studied it that closely. I *think* BATTMAN allows you to change the order. Quote
SLW210 Posted November 7, 2013 Posted November 7, 2013 AFAIK, if the OP is using 2008 LT, BATTMAN is not available. Quote
Tuns Posted November 7, 2013 Posted November 7, 2013 They are displayed in the order that you make them. For example, if you make attribute x, then attribute y, then z, it will be displayed in that order. Quote
dbroada Posted November 7, 2013 Posted November 7, 2013 AFAIK, if the OP is using 2008 LT, BATTMAN is not available.neither spotted that nor remembered it wasn't available in that release. Thanks. Quote
steven-g Posted November 7, 2013 Posted November 7, 2013 If the attributes are created inside the block editor, then it is the order they are created. If you create them in model space it is in the reverse order of how they are created if you use window selection, if you pick them individually then it is pick order. Quote
SLW210 Posted November 7, 2013 Posted November 7, 2013 I moved this thread to the AutoCAD LT forum. Quote
