legg1979 Posted November 10, 2013 Posted November 10, 2013 I am trying to run a lisp from a setq. Im sure there is a more efficient way but Im self tough & have minimal knowledge. I have a lisp that I want to use for a number of block inserts, text notes & a few various other things. Im not looking for a rewritten code I just need to be able to run a "defun" from a setq. The setq's at the beginning of the code are the only things that will change in each file. I did have the code working but had to go thru & find & edit each difference. I am trying to make it a lot easier to change. her is an extract of my code. I have a seperate c:defun that is run and calls up the "the-sub-command" & I have both the new1 & new2 defun's written in the same lisp. my problem is running either new1 or new2 (setq value-1 "changeable-value") ;this is the 1st stored value (setq new1 (strcat value-1 "generic text1")) ;this is the 1st stored value combined with a 1st generic value. (setq new2 (strcat value-1 "generic text2")) ;this is the 1st stored value combined with a 2nd generic value. (defun the-sub-command() (initget 1 "EXG PROP") (setq exg-prop (getkword "\nExisting or Proposed? [Existing/Proposed]: ")) ;get INFO (COND ((= exg-prop "EXG") new1) ((= exg-prop "PROP") new2) (T (prompt "\nOpps there was an error!")) ) (princ) ) (defun new1() ......the commands (princ) ) (defun new2() ......the commands (princ) ) Quote
BlackBox Posted November 10, 2013 Posted November 10, 2013 ;; ... (COND ((= exg-prop "EXG") [b][color="red"]([/color][/b]new1[b][color="red"])[/color][/b]) ((= exg-prop "PROP") [b][color="red"]([/color][/b]new2[b][color="red"])[/color][/b]) (T (prompt "\nOpps there was an error!")) ) ;; ... Quote
legg1979 Posted November 11, 2013 Author Posted November 11, 2013 Thanks for the reply but I had tried that prior to my post & just double checked with not success. The command that it is trying to run doesnt have a C: before the Defun. When running the code instead of the command running I get an error in the command line ; error: bad function: "changeable-valuegeneric text1" Quote
MSasu Posted November 11, 2013 Posted November 11, 2013 What BlackBox advised you is correct! Please pay attention that the New1/New2 functions seems to be defined after where called; this issue is masked by the fact that you used the same symbols to store a string and later a function definition! Quote
legg1979 Posted November 11, 2013 Author Posted November 11, 2013 Thanks, So is what im trying to do my achievable? I am sort of trying to learn LIPS by over coming issues when they arise so if there is a correct way could someone please point me in the right direction Cheers Quote
MSasu Posted November 11, 2013 Posted November 11, 2013 I see no reasons why cannot be achived! Try to adjust your code like below: (setq value-1 "changeable-value") ;this is the 1st stored value (setq [color=red][s]new1[/s] string1[/color] (strcat value-1 "generic text1")) ;this is the 1st stored value combined with a 1st generic value. (setq [color=red][s]new2[/s] string2[/color] (strcat value-1 "generic text2")) ;this is the 1st stored value combined with a 2nd generic value. [color=red];move function definitions here![/color] [color=blue](defun new1() ......the commands (princ) ) (defun new2() ......the commands (princ) )[/color] (defun the-sub-command() (initget 1 "EXG PROP") (setq exg-prop (getkword "\nExisting or Proposed? [Existing/Proposed]: ")) ;get INFO (COND ((= exg-prop "EXG") [color=red]([/color]new1[color=red])[/color]) ((= exg-prop "PROP") [color=red]([/color]new2[color=red])[/color]) (T (prompt "\nOpps there was an error!")) ) (princ) ) Quote
MSasu Posted November 11, 2013 Posted November 11, 2013 Two other comments: When you concatenate the strings shouldn't there be a space? (strcat value-1 [color=red]" "[/color] "generic text1") Second, woudn't be better to use one letters keywords for options? It match AutoCAD behavior and is simpler to use: (initget 1 "Existing Proposed") Also, the required input isn't suggested in your prompt (the "EXG" one isn't even intuitive). Quote
