DuggDaly Posted November 13, 2013 Author Posted November 13, 2013 When set up correctly, AutoCAD's dwg to pdf plotter plots exactly like plotting to paper. Maybe you should re-examine your page set-ups. I have explored every option that I can find. Hence, I am here asking for help. If I pick the page setup for the pdf 995 (where it works perfect) and simply change the plotter to dwg to pdf, I dont see how it is the page setup. I may be wrong? Quote
RobDraw Posted November 13, 2013 Posted November 13, 2013 We are getting away from the original topic. Maybe you can start a new thread for help getting your plot settings to work for both hard copy and PDF within AutoCAD. Sharing your settings and a sample dwg would be a good start. Quote
