hamid85 Posted December 1, 2006 Posted December 1, 2006 Hi friands, How can i convert some solid bodies to a single solid. Thanks Quote
SEANT Posted December 1, 2006 Posted December 1, 2006 The "_union" command will join several solids into one. It's siblings in the solid booleans line up are "_subtract" and "_intersect". All good stuff when it comes to solid bodies. Quote
ReMark Posted July 18, 2011 Posted July 18, 2011 SEANT's response refers to AutoCAD. Not sure if the same commands are available in Solidworks. Quote
JD Mather Posted July 18, 2011 Posted July 18, 2011 in solidworks or autocad?? Do you have a question about SolidWorks? If so, you should have posted a new thread in the SolidWorks area of the forum (I don't see where the OP ever mentioned SolidWorks). (By the way - in SolidWorks the command is Instert>Feature>Combine (name can be confusing as once you get into the Command you can do more than just Combine). Quote
techberth Posted July 18, 2011 Posted July 18, 2011 Do you have a question about SolidWorks? If so, you should have posted a new thread in the SolidWorks area of the forum (I don't see where the OP ever mentioned SolidWorks). (By the way - in SolidWorks the command is Instert>Feature>Combine (name can be confusing as once you get into the Command you can do more than just Combine). Thats I am asking to thread starter Quote
SLW210 Posted July 18, 2011 Posted July 18, 2011 Thats I am asking to thread starter The Thread Starter has not been to this site in nearly 5 years. The question is in the AutoCAD 3D Modelling & Rendering Forum, so I would surmise that it is AutoCAD related. Quote
JD Mather Posted July 18, 2011 Posted July 18, 2011 The Thread Starter has not been to this site in nearly 5 years. Just out of curiosity, what is this "Thread Starter" techberth referrs to? Quote
Patrick Hughes Posted July 19, 2011 Posted July 19, 2011 (edited) Just out of curiosity, what is this "Thread Starter" techberth referrs to? hamid85 - the OP originally posted: 1st Dec 2006 03:10 am Edited July 19, 2011 by Patrick Hughes added post date Quote
