djmikel Posted November 26, 2013 Share Posted November 26, 2013 The temporary tracking line on the distance command has disappeared. Any idea where this is controlled? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
djmikel Posted November 26, 2013 Author Share Posted November 26, 2013 Solved. If Layer 0 is frozen, the tracking line will not show. Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 26, 2013 Share Posted November 26, 2013 I was just going to type a response to check the value of the sys var trackpath. It turns on or off certain object tracking vectors. At certain settings, the vector for Distance won't show up either. 0 - Displays full-screen polar and object snap tracking paths 1 - Displays full-screen polar tracking path; displays object snap tracking path only between the alignment point and the From point to the cursor location 2 - Displays full-screen object snap tracking path; does not display polar tracking path 3 - Does not display polar tracking path; displays object snap tracking path only between the alignment point and the From point to the cursor location Quote Link to comment Share on other sites More sharing options...
