teknomatika Posted December 10, 2013 Posted December 10, 2013 I have this routine (unknown to the author), which lets you export to a text file the list of existing layers in a drawing. It works fine, but I wanted a version that could include one column for the description of each layer. Thank you in advance for your possible help. (defun c:LL2T ( / oecho clrlst dwgnm fn fh lyr lyrlst) (defun chkbit (bit_val num) (not (zerop (logand bit_val num))) ) (setq oecho (getvar "cmdecho") clrlst (list (cons 1 "RED") (cons 2 "YELLOW") (cons 3 "GREEN") (cons 4 "CYAN") (cons 5 "BLUE") (cons 6 "MAGENTA") (cons 7 "WHITE") ) dwgnm (getvar "dwgname") ) (setvar "cmdecho" 0) (setq fn (getfiled " File name: " (strcat dwgnm ".LS") "LS" (+ 1 2)) ) (while (setq lyr (tblnext "layer" (not lyr))) (setq lyrlst (cons (cdr (assoc 2 lyr)) lyrlst)) ) (setq lyrlst (acad_strlsort lyrlst)) (princ "\nWriting layer data to file...") (setq fh (open fn "w")) (princ (strcat dwgnm ".DWG\n") fh) (foreach x lyrlst (setq lyr (tblsearch "layer" x) lyrname (cdr (assoc 2 lyr)) lyrclr (cdr (assoc 62 lyr)) lyrlt (cdr (assoc 6 lyr)) frzn? (chkbit 1 (cdr (assoc 70 lyr))) lokd? (chkbit 4 (cdr (assoc 70 lyr))) ) (if (minusp lyrclr) (setq on? "OFF" lyrclr (abs lyrclr) ) (setq on? "ON") ) (if (assoc lyrclr clrlst) (setq lyrclr (cdr (assoc lyrclr clrlst))) ) (if frzn? (setq frzn? "FROZEN") (setq frzn? "THAWED") ) (if lokd? (setq lokd? "LOCKED") (setq lokd? "UNLOCKED") ) (princ lyrname fh) ;;(princ "," fh) ;;(princ lyrclr fh) ;;(princ "," fh) ;;(princ lyrlt fh) ;;(princ "," fh) ;;(princ on? fh) ;;(princ "," fh) ;;(princ frzn? fh) ;;(princ "," fh) ;;(princ lokd? fh) (princ "\n" fh) ) (princ "done.") (close fh) (setvar "cmdecho" oecho) (princ) ) Quote
