andycaddy Posted December 11, 2013 Posted December 11, 2013 When I create a pdf of a shaded 3D object the pdf shows up with pixelated edges. Is there a way to create a pdf of a shaded 3D object with smooth edges as it appears on screen? Quote
gazza_au Posted December 11, 2013 Posted December 11, 2013 Try saving / plotting as dwg to pdf not just pdf. Quote
MSasu Posted December 11, 2013 Posted December 11, 2013 On PLOT command's dialog, check for Shaded viewport options area and under Shade plot pop-up list choose the style you want. An advanced alternative will be to look for RENDER command. Quote
andycaddy Posted December 11, 2013 Author Posted December 11, 2013 I tried both of your suggestions and still no luck. I've attached a pdf to view. Thanks andycaddy.pdf Quote
andycaddy Posted December 11, 2013 Author Posted December 11, 2013 I figured out a solution to my problem. You have to make your viewport size relate to the print size. Quote
