OMEGA-ThundeR Posted December 12, 2013 Posted December 12, 2013 Hi, I am wondering if it is possible with an 3D autocad design to make a 'free roam' kind of walk through the design. I know how to make a video clip on a set path, but lets just say you create a road and a couple of houses next to it i kinda want to walk over the road/sidewalk like it were a game. Is that possible within the autodesk software range? Or do i need to transfer a design to an game engine and go from there? Any help or tips would be appreciated . Quote
Denimoth Posted December 12, 2013 Posted December 12, 2013 If you can save your 3D model into a 3D DWF format (AutoCAD 2010 can export to that format, but not sure if 2008 can do it.), you could use Autodesk's Navisworks Freedom viewer. It's free and allows you to "walk" around the model. http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-freedom Quote
OMEGA-ThundeR Posted December 12, 2013 Author Posted December 12, 2013 Thanks, and its free to . We got some Autocad packages, so i'll probably be able to export to 3D DWF. Quote
Murph_map Posted December 12, 2013 Posted December 12, 2013 Don't know if 2009 has it but try the "3dWalk" command. Quote
ReMark Posted December 12, 2013 Posted December 12, 2013 The 3DWalk command first made its appearance in AutoCAD 2007 I believe. Quote
OMEGA-ThundeR Posted December 12, 2013 Author Posted December 12, 2013 I changes my profile... i use Autocad 2014 nowadays:).. Quote
Katy Posted December 24, 2013 Posted December 24, 2013 I love to see 3D Walkthrough. My Favorite one is here. Quote
