The kludge meister, he'll be back. :beer:
rkent, one day you 'll have to teach us all the secret handshake. :)
um, thanks. Fax me a donut, I am hungry.
  • Replies 23
  • steven-g
    4
  • SEANT
    3
  • nestly
    3
  • Tuns
    3
Posted Images
...eldon's method is precisely what I had in mind...
Whoooooooo?!:shock::lol: I have to agree with your KIASAP mindset.
After seeing rkent's fantastic grip method (:thumbsup:) I decided it was time to turn off Expert so that I could see all the hidden options. Unfortunately, that didn't help... It wasn't on. Hmmmm.
  • 3 weeks later...
@ SEANT, that works fantastic for a single instance. :notworthy: If I could specify multiple destinations (2nd point) within the same command then it would be perfect for my application.
You could do it with 2 macros. I cannot yet find a way to do this using a single macro.
After you have run the initial macro
^C^C_Select \rotate previous ;\c;r @;
once then you could have a second macro that can continue the process until you choose to end it.
It would look like this:
*^C^CRotate;Last;;@;Copy;Reference;@;\\
rkent, one day you'll have to teach us all the secret handshake. :)
Adding another level to RKent's tip, hold CTRL after the first copy and AutoCAD will remember the previous increment or angle of the copied objects using the grip method.
~Greg
