how can i manipulate the selection by ssget function in cad interface
lyt8353381
maybe the title didn't interpret my problem i have a try to explain it explicitly.
first i use ssget chose a selection but in lisp code i didn't write how to manipulate this selection . i just want through the order in cad interface to operate it . oh! just like the "qselect" order in cad . you chose something that they have the same property and you can operate it through the order in toolbar.
my god i hope someone understand what i said
thanks for your scan
thanks for your help
but the five code just get the name of the entity that you select
for example :
i want use ssget select entity then use "move" button that in cad's interface to move what i select
thanks :shock:
