neilc Posted November 29, 2008 Posted November 29, 2008 Hi All, i have been creating drawings with raster design. When i look at the file references the drawing is made up of the following 1 - the autocad drawing 2 - the tiff image i have loaded 3 - a new image which has been created when i modified the laoded tiff. I want to send the drawing to a customer electronically. My question is this. If when i open up the drawing i want to send, the drawing is made up of another 2 tiff images stored on my local hard drive, how do i attach these images so the customer opens the drawing correctly? I tried the bind command but it comes up with no references to bind Thanks for any replies Quote
neilc Posted November 29, 2008 Author Posted November 29, 2008 i think i have sorted it with the embed command Quote
Tankman Posted November 29, 2008 Posted November 29, 2008 Neil: Tried both bind and embed, without success. I too would like to send the image with the *.dwg file. Keep me up to date if you find a solution. I'm just a dummy, plain plan views and elevation views. Too much board time I guess. Quote
Dipali Posted November 29, 2008 Posted November 29, 2008 use 'etransmit' command. it will bundle up everything attched to the file & also the required font files & ctb if used any in a zip folder ready to send. Quote
Tankman Posted November 29, 2008 Posted November 29, 2008 Just tried INSERTOBJ ~ worked great. Once the image(s) were in the *.dwg file, and sized, turned off, under modify image, frame. The image I had to (or perhaps not) save to a *.bmp, used M$'s Paint. Simple enough. I checked the image manager, no files there. Emailed the *.dwg to myself, opened and there were the images in the file without any other attached files, no Zip, nada, nothing. Excellent! Quote
neilc Posted November 30, 2008 Author Posted November 30, 2008 Ive sent the drawings to my customer with the embed command and and asked him to check if everything opens correctly. I have also emailed the drgs to myself (and changed the location of folders where the images are stored on my hard drive) and the drawings open up fine. The only command i have used is embed. I'll let you know if the drawings are ok at the customers end. Quote
