May i know how can i unblock my block ?! I got 3 floor in my drawing , when i select each of my floor , it automatic select all of my floors by 1 click.. may i know how to make it separately each floor by floor , because i need to copy floor by floor only...
Any solution for it ?!
Thank !
Create a copy of your drawing upon which to experiment with the following suggestion.
Open your copy, and use the EXPLODE command on the block.
Once you have done that, you should be at liberty to do whatever you want with the
different elements of it.
Thank You Very much ! By the way , may i know how to lock it back ?!
You could create new blocks using the WBLOCK command, for which you should create new appropriate and descriptive names.
Once it has been EXPLODED you cannot just push a button to reverse the process, although if you did it
by mistake you could use the UNDO command.
You will still have the original block in the original drawing, which is why I advised you to make a copy and work on it,
lest the block which you were supplied become compromised or damaged.
Edited by Dadgad
If you want it to remain a block, then just open it in the Block Editor and copy out what you want.
I think that NCOPY would be another available option.
I love that command!
What about REFEDIT? I think that would work as well.
