Xpeter88 Posted January 4, 2014 Posted January 4, 2014 (edited) Hi All, I am trying to create one macro to update the AutoCAD drawings - just select texts, mtexts, lines and modify their properties like lineweight, text size, text style. So my drawings contains lines, Texts or MTexts and Attribute References - these files are future blocks. All works fine and I believe that I am very close to finish but there is one thing that causes issues. The problem occures when I am trying to select Attribute References and modify their text height. I have no idea how to select them. I tried to set FilterTypeText(1) = 2 FilterDataText(1) = "*" For Each entity In sstext entity.color = acByLayer entity.Height = 3.5 Next but it will select some entities for which cannot mofify the text height - there is not such property and I get an error. For now I put On Error Resume Next that will continue next on error but want to solve this. See my code below. Sub UpdateBlocks() Dim sstext As AcadSelectionSet Dim FilterTypeText(3) As Integer Dim FilterDataText(3) As Variant Dim tsObject As AcadTextStyle Dim ent As AcadEntity Dim ssall As AcadSelectionSet Dim layer As AcadLayer Dim entity As AcadEntity On Error Resume Next 'set acwhite for each layer in the drawing For Each layer In ThisDrawing.Layers layer.color = acWhite Next 'set all text styles For Each tsObject In ThisDrawing.TextStyles tsObject.fontFile = "SIMPLEX.shx" tsObject.Width = 0.8 tsObject.Height = 3.5 Next 'select all entities and change the lineweight and color Set ssall = ThisDrawing.SelectionSets.Add("SelectAll") ssall.Select acSelectionSetAll For Each ent In ssall ent.Lineweight = acLnWt000 ent.color = acByLayer Next ssall.Clear ssall.Delete 'select and change all text and Mtext Set sstext = ThisDrawing.SelectionSets.Add("SelectText") FilterTypeText(0) = -4 FilterDataText(0) = "" sstext.Select acSelectionSetAll, , , FilterTypeText, FilterDataText For Each entity In sstext entity.color = acByLayer entity.Height = 3.5 Next sstext.Clear sstext.Delete 'need select all the block attributes and move them to the standard text style or at least modify the size and textstyle ThisDrawing.Application.ActiveDocument.PurgeAll End Sub Many thanks for any help, Peter Edited January 4, 2014 by Xpeter88 Quote
RICVBA Posted January 4, 2014 Posted January 4, 2014 Hi All,I am trying to create one macro to update the AutoCAD drawings - just select texts, mtexts, lines and modify their properties like lineweight, text size, text style. So my drawings contains lines, Texts or MTexts and Attribute References - these files are future blocks. All works fine and I believe that I am very close to finish but there is one thing that causes issues. The problem occures when I am trying to select Attribute References and modify their text height. I have no idea how to select them. I tried to set FilterTypeText(1) = 2 FilterDataText(1) = "*" For Each entity In sstext entity.color = acByLayer entity.Height = 3.5 Next but it will select some entities for which cannot mofify the text height - there is not such property and I get an error. For now I put On Error Resume Next that will continue next on error but want to solve this. See my code below. Sub UpdateBlocks() Dim sstext As AcadSelectionSet Dim FilterTypeText(3) As Integer Dim FilterDataText(3) As Variant Dim tsObject As AcadTextStyle Dim ent As AcadEntity Dim ssall As AcadSelectionSet Dim layer As AcadLayer Dim entity As AcadEntity On Error Resume Next 'set acwhite for each layer in the drawing For Each layer In ThisDrawing.Layers layer.color = acWhite Next 'set all text styles For Each tsObject In ThisDrawing.TextStyles tsObject.fontFile = "SIMPLEX.shx" tsObject.Width = 0.8 tsObject.Height = 3.5 Next 'select all entities and change the lineweight and color Set ssall = ThisDrawing.SelectionSets.Add("SelectAll") ssall.Select acSelectionSetAll For Each ent In ssall ent.Lineweight = acLnWt000 ent.color = acByLayer Next ssall.Clear ssall.Delete 'select and change all text and Mtext Set sstext = ThisDrawing.SelectionSets.Add("SelectText") FilterTypeText(0) = -4 FilterDataText(0) = "" sstext.Select acSelectionSetAll, , , FilterTypeText, FilterDataText For Each entity In sstext entity.color = acByLayer entity.Height = 3.5 Next sstext.Clear sstext.Delete 'need select all the block attributes and move them to the standard text style or at least modify the size and textstyle ThisDrawing.Application.ActiveDocument.PurgeAll End Sub Many thanks for any help, Peter Hi Xpeter88 at the beginning you declared "3" as the upper bound for FilterTypeText and FilterDataText vectors (i.e. they will have 4 items), but when setting filters you only set their 2nd item (index "1" - these vectors are zero based ones). this results in an error. you'd Always better avoid the "On Error Resume Next" instruction while debugging so as to understand at least where you get the error. furthermore, even with proper setting of vectors upperbound and indexes (both "0"), with your selection criteria you would get all objects in the drawing since you are filtering by name (Group Code =2) but then accepting every name (value="*"). Instead to select all text and mtexts you could set filters as follows Dim FilterTypeText(3) As Integer Dim FilterDataText(3) As Variant FilterTypeText(0) = -4: FilterDataText(0) = "<OR" FilterTypeText(1) = 0: FilterDataText(1) = "TEXT" FilterTypeText(2) = 0: FilterDataText(2) = "MTEXT" FilterTypeText(3) = -4: FilterDataText(3) = "OR>" while for acting on attribute references associated with inserted block references you could act as follows 1) select all block references Dim gpCode(0) As Integer Dim dataValue(0) As Variant Dim ssetObj As AcadSelectionSet 'selecting block references in the active drawing gpCode(0) = 0 dataValue(0) = "INSERT" On Error Resume Next Set ssetObj = ThisDrawing.SelectionSets.Add("BlockRefSset") If Err <> 0 Then Set ssetObj = ThisDrawing.SelectionSets.Item("BlockRefSset") Else ssetObj.Clear End If On Error GoTo 0 ssetObj.Select acSelectionSetAll, , , gpCode, dataValue 2) then iterate through the selectionset and acting on items who have attributes 'handling block references found Dim nBlckRefs As Integer, iBlckRef As Integer, iAttr As Integer Dim Attrs As Variant Dim LBnd As Integer, Ubnd As Integer nBlckRefs = ssetObj.Count For iBlckRef = 0 To nBlckRefs - 1 Set myBlckRef = ssetObj.Item(iBlckRef) If myBlckRef.HasAttributes Then With myBlckRef Attrs = .GetAttributes End With LBnd = LBound(Attrs) Ubnd = UBound(Attrs) For iAttr = LBnd To Ubnd Attrs(iAttr).Height = 3.5 Attrs(iAttr).Color = acByLayer Next iAttr End If Next iBlckRef Quote
Xpeter88 Posted January 4, 2014 Author Posted January 4, 2014 Hi, thanks for your reply. I did a test and works fine but what I am looking for is to select atribute definition and modify it which is not a part of block (yet). So these attribute definition are not inside the block. The reason is that library of "blocks" (we can call it drawings) does not contain any blocks - just lines, attribute definitions, texts and mtexts. These drawings are converted to blocks once they are inserted into the drawing and I am trying to modify these entities before they become blocks. e.g. if you type command "attdef" in commandline and put this into the drawing - it's attribute defininion but not as a part of the block yet. Hope it is clear:) Because of this I think that code below have to be defined a bit different. gpCode(0) = 0 dataValue(0) = "INSERT" I just cannot select these att definitions inside the active drawing. btw thanks for that 1st selection set (3), yes, there was a misstake:) Any ideas? Peter Quote
Tyke Posted January 4, 2014 Posted January 4, 2014 I'm not on my CAD computer at the moment, but I think if you use: gpCode(0) = 0 dataValue(0) = "ATTDEF" it should only pick up the attribute definitions. Quote
Xpeter88 Posted January 4, 2014 Author Posted January 4, 2014 Yes that's correct. I knew that I am close but this really did not come on my mind. I am still learning to VBA. Thank you both gyus, you really helped me. Have a nice day! Peter Quote
BIGAL Posted January 5, 2014 Posted January 5, 2014 With VBA being phased out you may want to think about going to VL or .net so dont get caught with code not working. This may be usefull Dim SS As AcadSelectionSet Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant Dim attribs As Variant BLOCK_NAME = "SCHEDTEXT" FilterDXFCode(0) = 0 FilterDXFVal(0) = "INSERT" 'FilterDXFCode(1) = 2 'FilterDXFVal(1) = "SCHEDTEXT" Set SS = ThisDrawing.SelectionSets.Add("pit1sel") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 If SS.Item(Cntr).Name = BLOCK_NAME Then attribs = SS.Item(Cntr).GetAttributes If attribs(0).TextString = pitname Then ' attribs start at 0 attrib(3) would be the 4th attribute in the block Quote
Xpeter88 Posted January 5, 2014 Author Posted January 5, 2014 I know about that but for this purpose this will be enough. This code will be just a part of another code that I already have in VBA (it reads records from excel, opens the drawings, changing the attribute values + this new part will update the textsize, colors, lines...). I am learning to .NET and probably they will be re-writed to .NET but I am not able to do it now as the steps and syntax is a bit different from VBA. At least I will have working code in VBA that works and a good and can take advantage of it's steps to rewrite it to .NET BTW when we started to talk about .NET I know that there is a code which can transfer VBA to .NET. Do you have any expirience wiht that if it works or it's better to completly rewrite it manually. Quote
Xpeter88 Posted January 5, 2014 Author Posted January 5, 2014 And thanks for that piece of code Inwill try it as soon as I get to my laptop. Quote
Tyke Posted January 5, 2014 Posted January 5, 2014 BTW when we started to talk about .NET I know that there is a code which can transfer VBA to .NET. Do you have any expirience wiht that if it works or it's better to completly rewrite it manually. Kean Walmsley and his team from Autodesk Tech Dev produced a magic macro that will convert VBA code to VB.NET, but depending on the quality of the VBA code it has differing results. It will also convert the VB6 forms to .NET, but here again there are limitations. When I last used it you had to open the code produced from the Magic Macro in VB.NET 2008 save your project and then open it in the later versions of VB.NET you are using. I think VB.NET 2008 Express is still available as a free download if you need it. My experience using it was that there was sometimes a massive amount of debugging to do when you got your code into VB.NET and some of the VBA controls on the forms were not available in .NET. For smaller VBA projects it is really not worth all the effort to use the converter and with the larger projects it can also be a big job to get it running. Have a look at this video if you want to investigate it further: http://download.autodesk.com/media/adn/VBA_Migration/DevTV_Recording/VBA_Migration.html I now either write the code in .NET or in VBA and don't even consider using the converter. Just as an aside Autodesk no long supports VBA6 but have introduced VBA7 in AutoCAD 2014 which uses 64-bit controls on the forms, 32-bit controls are no longer supported. There are also other differences, that means the code you write in VBA6 will not necessarily run in VBA7. Whilst Autodesk have said they will continue to support VBA7 in future versions of Autodesk products they will only do that so long as Microsoft supports VBA, and that could change at any time in the future. There are no such issues with .NET so I would recommend that you change to one of the Visual Studio languages and forget writing new code in VBA. There will always be maintenance to VBA code to do and perhaps a few enhancements to existing code, so don't throw VBA completely out of the window. Quote
Xpeter88 Posted January 6, 2014 Author Posted January 6, 2014 Tyke, thanks for your opinion. For now I don't need to transfer VBA to .NET but I am learning to VB.NET conventions so probably my future codes will be done in VB.NET to avoid any other issues. Quote
