PaulS00 Posted January 7, 2014 Share Posted January 7, 2014 Hello, I've drawn out a storm drain system using Pipes and am running into a problem with the label flowlines. As pictured below, there are 2 south running flowlines, but the one on the right should read (SW) instead of (S). In the label style editor, there are no additional settings for "Connected Pipe Direction." Thoughts? Quote Link to comment Share on other sites More sharing options...
Bill_Myron Posted January 8, 2014 Share Posted January 8, 2014 The direction labels work in 45° quadrants. 22.5° either side of N, E, S, W. So if your pipe is less than 22.5° from due South, that's what it will be labelled as. Quote Link to comment Share on other sites More sharing options...
