AGove4123Sonnnnn Posted January 7, 2014 Posted January 7, 2014 (edited) Any Ideas why this guy won't compile? Private Function GetPointsFromBlock(strBlockName As String) As IAcadPoint2 'Retreives and groups points from a given block... 'Get AutoCAD, dimension variables and initialize counters Set ACAD = GetObject(, "AutoCAD.Application") Set DOCfrom = ACAD.ActiveDocument Dim i As Integer: i = 0 Dim intPCount As Integer: intPCount = 0 Dim blkActiveBlock As AcadBlock Dim pntActivePoints() As IAcadPoint2 Set blkActiveBlock = DOCfrom.Blocks(strBlockName) 'Count how many points there are and redim the storage array For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then ReDim pntActivePoints(0 To intPCount) intPCount = intPCount + 1 End If i = i + 1 Next 'Place point objects into array i = 0: intPCount = 0 For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then Set pntActivePoints(intPCount) = blkActiveBlock.Item(i) intPCount = intPCount + 1 End If i = i + 1 Next Debug.Print intPCount & " points were found in " & strBlockName & "!" Set GetPointsFromBlock = pntActivePoints End Function Edited January 8, 2014 by AGove4123Sonnnnn Incorrect formatting Quote
SLW210 Posted January 8, 2014 Posted January 8, 2014 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote
RICVBA Posted January 8, 2014 Posted January 8, 2014 my Autocad2010 VBA doesn't manage IAcadPoint2 class (when selecting this keyword and pressing F1 it sends me to AcadPoint Class (Point Object)) so I can only give you the following guessings of mine: 1) I'd say you can't set a simple object (like "GetPointsFromBlock as IAcadPoint2" is) to a vector of objects. you need a simple object on the right side of the setting codeline too 2) maybe you'l find the following code useful for your purposes Option Explicit Public Type MyPointType coord2D(0 To 1) As Double coord3D(0 To 2) As Double End Type ' you can enlarge the properties to match your needs Sub main() Dim MyPoints() As MyPointType, MyPoint As MyPointType Dim Points2D() As Double, Points3D() As Double Dim AcdPnt As AcadPoint Dim strBlockName As String Dim PntsTotNr As Integer, iPnt As Integer Dim plineObj As AcadPolyline Dim LWplineObj As AcadLWPolyline strBlockName = "MyBlock" Call GetPointsFromBlock2(strBlockName, PntsTotNr, MyPoints, Points2D, Points3D) '... do whatever you need with: ' - Points() single points vector, every item of which contains both 2D and 3D coordinates vectors of a single point ' - Points2D, containing all points coordinates in 2D form ' - Points3D, containing all points coordinates in 3D form ' for example ' use single point coordinates For iPnt = 1 To PntsTotNr MyPoint = MyPoints(iPnt - 1) Set AcdPnt = ThisDrawing.ModelSpace.AddPoint(MyPoint.coord3D) AcdPnt.color = acRed Next iPnt ' use all points coordinates, in the proper 2D/3D form If PntsTotNr > 1 Then ' for methods requiring 2D coordinates Set LWplineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(Points2D) LWplineObj.color = acWhite ' for methods requiring 3D coordinates Set plineObj = ThisDrawing.ModelSpace.AddPolyline(Points3D) With plineObj .color = acGreen .Move MyPoints(0).coord3D, MyPoints(PntsTotNr - 2).coord3D End With End If ZoomExtents End Sub Sub GetPointsFromBlock2(strBlockName As String, PntsTotNr As Integer, Points() As MyPointType, Points2DCoords() As Double, Points3DCoords() As Double) 'Retreives and groups points (and vertices if needed) coordinates from a given block... 'Get AutoCAD, dimension variables and initialize counters Dim DOCfrom As AcadDocument Dim Object As AcadObject Set acad = GetObject(, "AutoCAD.Application") Set DOCfrom = acad.ActiveDocument Dim i As Integer: i = 0 Dim intPCount As Integer: intPCount = 0 Dim blkActiveBlock As AcadBlock Dim pntActivePoints() As IAcadPoint2 Set blkActiveBlock = DOCfrom.Blocks(strBlockName) Dim retCoord As Variant Dim objName As String Dim uBnd As Integer, lBnd As Integer, PntsNr As Integer, CoordDims As Integer Dim x As Double, y As Double, z As Double PntsTotNr = 0 'go through every object in the block For Each Object In blkActiveBlock With Object objName = .ObjectName retCoord = .Coordinates End With uBnd = UBound(retCoord) lBnd = LBound(retCoord) ' mark only relevant objects assigning the proper CoordDims Select Case objName Case "AcDbPoint" '(3D-Polyline) ' 3D coordinates CoordDims = 3 'in case you need objects vertices coordinates too, uncomment and enhance the following lines ' Case "AcDbPolyline" ' (LWPolyline) ' ' 2D coordinates ' CoordDims = 2 ' ' Case "AcDb3dPolyline" '(3D-Polyline) ' ' 3D coordinates ' CoordDims = 3 Case Else ' not handled objects CoordDims = 0 End Select 'process relevant blocks only If CoordDims > 0 Then PntsNr = (uBnd - lBnd + 1) / CoordDims PntsTotNr = PntsTotNr + PntsNr ReDim Preserve Points(0 To PntsTotNr - 1) ReDim Preserve Points2DCoords(0 To 2 * PntsTotNr - 1) ReDim Preserve Points3DCoords(0 To 3 * PntsTotNr - 1) For i = 1 To PntsNr x = retCoord(CoordDims * (i - 1)) y = retCoord(CoordDims * (i - 1) + 1) If CoordDims = 3 Then z = retCoord(CoordDims * (i - 1) + 2) Else z = 0 End If Points2DCoords(2 * intPCount) = x Points2DCoords(2 * intPCount + 1) = y Points3DCoords(3 * intPCount) = x Points3DCoords(3 * intPCount + 1) = y If CoordDims = 3 Then Points3DCoords(1) = z With Points(intPCount) .coord2D(0) = x .coord2D(1) = y .coord3D(0) = x .coord3D(1) = y If CoordDims = 3 Then .coord3D(2) = z End With intPCount = intPCount + 1 Next i End If Next Object Set acad = Nothing End Sub Quote
AGove4123Sonnnnn Posted January 8, 2014 Author Posted January 8, 2014 RICVBA! Your right... what is that IAcadPoint2 type anyway? I got it from the data type autocad was returning while the array was set to a variant. Anyway switching up the code to use the standard AcadPoint worked swimmingly. Thanks for the code ideas too! What worked - Private Function GetPointsFromBlock(strBlockName As String) 'Retreives and groups points from a given block... 'Get AutoCAD, dimension variables and initialize counters Set ACAD = GetObject(, "AutoCAD.Application") Set DOCfrom = ACAD.ActiveDocument Dim i As Integer: i = 0 Dim intPCount As Integer: intPCount = 0 Dim blkActiveBlock As AcadBlock Dim pntActivePoints() As AcadPoint Set blkActiveBlock = DOCfrom.Blocks(strBlockName) 'Count how many points there are and redim the storage array For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then ReDim pntActivePoints(0 To intPCount) intPCount = intPCount + 1 End If i = i + 1 Next 'Place point objects into array i = 0: intPCount = 0 For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then Set pntActivePoints(intPCount) = blkActiveBlock.Item(i) intPCount = intPCount + 1 End If i = i + 1 Next Debug.Print intPCount & " points were found in " & strBlockName & "!" GetPointsFromBlock = pntActivePoints End Function Quote
RICVBA Posted January 8, 2014 Posted January 8, 2014 RICVBA! Your right... what is that IAcadPoint2 type anyway? I got it from the data type autocad was returning while the array was set to a variant. Anyway switching up the code to use the standard AcadPoint worked swimmingly. Thanks for the code ideas too! What worked - Private Function GetPointsFromBlock(strBlockName As String) 'Retreives and groups points from a given block... 'Get AutoCAD, dimension variables and initialize counters Set ACAD = GetObject(, "AutoCAD.Application") Set DOCfrom = ACAD.ActiveDocument Dim i As Integer: i = 0 Dim intPCount As Integer: intPCount = 0 Dim blkActiveBlock As AcadBlock Dim pntActivePoints() As AcadPoint Set blkActiveBlock = DOCfrom.Blocks(strBlockName) 'Count how many points there are and redim the storage array For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then ReDim pntActivePoints(0 To intPCount) intPCount = intPCount + 1 End If i = i + 1 Next 'Place point objects into array i = 0: intPCount = 0 For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then Set pntActivePoints(intPCount) = blkActiveBlock.Item(i) intPCount = intPCount + 1 End If i = i + 1 Next Debug.Print intPCount & " points were found in " & strBlockName & "!" GetPointsFromBlock = pntActivePoints End Function Hi Agove glad it works can't be of any help as to IAcadpoint2 class. maybe other people here could answer you. bytheway I think you could sensibly shorten your code making one "for each-next" loop only out of the two you're using the "Preserve" of ReDim instruction keyword as follows 'Count how many points there are [u]while[/u] redim the storage array and place point objects into it i = 0: intPCount = 0 For Each Object In blkActiveBlock If blkActiveBlock.Item(i).EntityType = 22 Then ReDim Preserve pntActivePoints(0 To intPCount) Set pntActivePoints(intPCount) = blkActiveBlock.Item(i) intPCount = intPCount + 1 End If i = i + 1 Next bye Quote
AGove4123Sonnnnn Posted January 8, 2014 Author Posted January 8, 2014 Thanks for the time saver! It kept deleting my data when I redimmed in the same loop and was running too late to look up the propper preserve syntax. Pce RIC, -AGove Quote
