dropoff510 Posted January 26, 2014 Share Posted January 26, 2014 I'm writing a program to import a WMF into the AutoCad Drawing. I haven't been able to find any reference for the import command, so I can't figure out why it's not working. According to Visual Studio, the Import command needs these things to work. Import(String FileName, Object InsertionPoint, Double ScaleFactor) Simplified Code: Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Interop Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication AcadApp = CType(GetObject(, "AutoCAD.Application.18.2"), Autodesk.AutoCAD.Interop.AcadApplication) acadDoc = AcadApp.ActiveDocument acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", New Point3d(2, 2, 0), 2.0) When I comment out the last line of code, acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", New Point3d(2, 2, 0), 2.0) It runs fine. The error I'm getting is when I run it AutoCAD, ************** Exception Text ************** System.ArgumentException: Value does not fall within the expected range. at System.StubHelpers.ObjectMarshaler.ConvertToNative(Object objSrc, IntPtr pDstVariant) at Autodesk.AutoCAD.Interop.IAcadDocument.Import(String FileName, Object InsertionPoint, Double ScaleFactor) at TestSelectingFiltering.TestSelecting.MyCommands.FilterBlueCircleOnLayer0() at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke() Any help would be greatly appreciated, Thanks! Quote Link to comment Share on other sites More sharing options...
dropoff510 Posted January 27, 2014 Author Share Posted January 27, 2014 Thanks to norman.yuan, solved it. Turns out I need to write the location code like this: Dim point(0 To 2) as double point(0)=2.0 : point(1)=2.0 : point(2)=0.0 acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", point, 2.0) Quote Link to comment Share on other sites More sharing options...
