scubadoo Posted December 1, 2008 Share Posted December 1, 2008 Hi guys I have a drawing I created on a previous computer that has A LOT of TIFF's inserted. I'm trying to open it now on my new PC and the rasters aren't displaying because the paths have changed and it says IMAGE NOT SUPPORTED. Is there a way of getting AutoCAD to recognise where the files are automatically, or do i need to manually change the paths? If the latter, can you remind me how to do it as I can't remember where to manage the paths. The Tiff's are all still in the correct folders but the start of the paths has changed. I'm using AutoCAD MAP 3D 2008. I've been away from AutoCAD for about a year and I think I've forgotten more than I ever knew . Cheers Dave Quote Link to comment Share on other sites More sharing options...
soleary Posted December 1, 2008 Share Posted December 1, 2008 Hi guys I have a drawing I created on a previous computer that has A LOT of TIFF's inserted. I'm trying to open it now on my new PC and the rasters aren't displaying because the paths have changed and it says IMAGE NOT SUPPORTED. Is there a way of getting AutoCAD to recognise where the files are automatically, or do i need to manually change the paths? If the latter, can you remind me how to do it as I can't remember where to manage the paths. The Tiff's are all still in the correct folders but the start of the paths has changed. I'm using AutoCAD MAP 3D 2008. I've been away from AutoCAD for about a year and I think I've forgotten more than I ever knew . Cheers Dave There was a thread similar to this recently http://www.cadtutor.net/forum/showthread.php?t=29730 Quote Link to comment Share on other sites More sharing options...
scubadoo Posted December 5, 2008 Author Share Posted December 5, 2008 There was a thread similar to this recently http://www.cadtutor.net/forum/showthread.php?t=29730 Thanks soleary. My fault, i forgot to do a search first . I guess there's no quick way then other than browsing to a new bath. Ah well. So if i have all the Jpegs and Tiff's in the same folder as the dwg then it will work even if switched to a different PC? My only worry is having a folder with hundreds of images in alongside my dwg. I'll see how it goes. Quote Link to comment Share on other sites More sharing options...
