Joeychgo Posted February 25, 2014 Share Posted February 25, 2014 when i export my drawings to pdf and then print them them i am not seeing any line weight. can someone explain to me? Quote Link to comment Share on other sites More sharing options...
Guest Trekiez Posted February 26, 2014 Share Posted February 26, 2014 What version of AutoCAD are you using? Are the lineweights visible in the drawing itself? If not, try clicking the Show/Hide Lineweight button and the bottom left of the screen (Next to the Northing, Easting - Using AutoCAD 2014). Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 26, 2014 Share Posted February 26, 2014 The version the OP is using is listed under his avatar. In this case it appears to be AutoCAD 2013. PDF output is at times so unpredictable it's a wonder CAD users even consider its use. Yes, I've heard all the arguments but I still avoid them like the plague. Quote Link to comment Share on other sites More sharing options...
eldon Posted February 26, 2014 Share Posted February 26, 2014 Have you tried Plotting to PDF? There is a check box for plotting lineweights. Perhaps Exporting to PDF does not have so many options Quote Link to comment Share on other sites More sharing options...
