Isolate Layer in Viewport (freeze instead of turn off all other layers)
Does anyone know if there is a way (lisp) that will isolate a selected layer within a viewport by FREEZING (VP Freeze) all other layers instead of just turning them off?
I create a lot of viewports for a legend and usually just need one layer on/thawed in those viewports. The advantage is hatching scales should always match.
I found that if each viewport has a lot of layers that are not frozen, the regen time will slow down significantly.
Thanks, Mike
The command Vplayer will do what you want its like layer command but in a viewport, you just make the layer you want current, then off, *, accept current on, all done.
