Rhayes
Drawing Tags
Rhayes
I have a Drawing that has Non-Annotative Tags at 1/16 scale. They are to small for the Drawing and I want to make them larger. I change the block with the block editor and the tag lines change however the text stays the same size.??? It looks correct in the block edit. But in the drawing the scale is all messed up.???
How can I modify an entire sheet of Blocks and have then all view correctly.???
I do not want to have re-tag the entire drawing.
Share this post
Link to post
NBC
Type in ATTSYNC at the command line, select the block with the 'erroneous' attributes, and voila; job's a good un.
Share this post
Link to post
Rhayes
Thanks... Worked like a charm.....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
