mostafa badran Posted March 9, 2014 Author Posted March 9, 2014 Thank for all replies,even the benefit for everyone, I found lisp by lee mac I think it it gave to me best result thank for everyone. Quote
BIGAL Posted March 28, 2014 Posted March 28, 2014 Well finally did it pick points and you have 3 options Enter 3 offsets pline 3 units auto to the right Enter -5,2 offsets pline 5 units auto to the left and with a width of 2 Enter -5,2,140 offsets pline 5 units auto to the left and with a width of 2 and with a colour of 140 This could be modified to do lots of things pline on layer 22,5,125,GRND you get the idea ; multiple pline including width & col function ; single entry is offset only ; two values 3,1 means offset 3 with width 1 ; three values 3,2,1 means offset 3 with start width 2 end 1 ; by Alan H March 2014 ; thanks to Lee-mac for this defun (defun _csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2)))) (list str) ) ) (defun aH:multpl ( / pt1 pt2 pt3 obj1 obj2 dist1 pwidst plcol lst howmany) (setvar "PLINEWID" 0) ;set PL width to 0 (command "_pline") (while (= (getvar "cmdactive") 1 ) (command pause) ) (setq pt1 nil) (setq obj1 (entlast)) ; grab pline (setq pt1 (getvar "lastpoint")) ; last pt (command "circle" pt1 100.0) ; do something smart here like screen scale for circle (setq obj2 (entlast)) ;grab circle (setq pt2 (vlax-invoke (vlax-ename->vla-object obj1) 'intersectWith (vlax-ename->vla-object obj2) acextendnone)); find int point (setq ang (angle pt1 pt2)) ;angle of pline now know left right (command "erase" "last" "") ; remove circle (while (/= (setq offval (getstring "Enter offset distance -ve for left")) "") (setq lst (cons (_csv->lst offval) lst)) (setq howmany (length (nth 0 lst))) ;determines single or multi answer (if (= howmany 1)(setq dist1 (atof (nth 0 (nth 0 lst)))) ) (if (= howmany 2) (progn (setq dist1 (atof (nth 0 (nth 0 lst)))) (setq pwidst (atof (nth 1 (nth 0 lst)))) ) ; progn ); if (if (= howmany 3) (progn (setq dist1 (atof (nth 0 (nth 0 lst)))) (setq pwidst (atof (nth 1 (nth 0 lst)))) (setq pLcol (atof (nth 2 (nth 0 lst)))) ) ; progn ); if (if (> dist1 0.0) (setq pt3 (polar pt2 (+ ang (/ pi 2.0)) (abs dist1))) (setq pt3 (polar pt2 (- ang (/ pi 2.0)) (abs dist1))) ) (command "offset" (abs dist1) obj1 pt3 "") (if (>= howmany 2) (vla-put-ConstantWidth (vlax-ename->vla-object (entlast)) pwidst) ) (if (= howmany 3) (vla-put-color (vlax-ename->vla-object (entlast)) plcol) ; note color as a number ) ) ; end while (command "erase" obj1 "") ) ; end defun (AH:multpl) (princ) Quote
