Thank for all replies,even the benefit for everyone, I found lisp by lee mac I think it it gave to me best result thank for everyone.:)
  • 3 weeks later...
  • Replies 21
  • mostafa badran
    11
  • lucas3
    4
  • BIGAL
    3
  • JamCAD
    3
Posted Images
Well finally did it pick points and you have 3 options
Enter 3 offsets pline 3 units auto to the right
Enter -5,2 offsets pline 5 units auto to the left and with a width of 2
Enter -5,2,140 offsets pline 5 units auto to the left and with a width of 2 and with a colour of 140
This could be modified to do lots of things pline on layer 22,5,125,GRND you get the idea
; multiple pline including width & col function
; single entry is offset only
; two values 3,1 means offset 3 with width 1
; three values 3,2,1 means offset 3 with start width 2 end 1
; by Alan H March 2014
; thanks to Lee-mac for this defun
(defun _csv->lst ( str / pos )
(if (setq pos (vl-string-position 44 str))
   (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
   (list str)
(defun aH:multpl ( / pt1 pt2 pt3 obj1 obj2 dist1 pwidst plcol lst howmany)
(setvar "PLINEWID" 0) ;set PL width to 0
(command "_pline")
(while (= (getvar "cmdactive") 1 ) (command pause)
(setq pt1 nil)
(setq obj1 (entlast)) ; grab pline
(setq pt1 (getvar "lastpoint")) ; last pt
(command "circle" pt1 100.0) ; do something smart here like screen scale for circle
(setq obj2  (entlast)) ;grab circle
(setq pt2 (vlax-invoke (vlax-ename->vla-object obj1) 'intersectWith (vlax-ename->vla-object obj2) acextendnone)); find int point
(setq ang (angle pt1 pt2)) ;angle of pline now know left right
(command "erase" "last" "") ; remove circle
(while (/= (setq offval (getstring "Enter offset distance -ve for left")) "")
(setq lst (cons (_csv->lst offval) lst))
(setq howmany (length (nth 0 lst))) ;determines single or multi answer
(if (= howmany 1)(setq dist1 (atof (nth 0 (nth 0 lst)))) )
(if (= howmany 2)
  (setq pwidst (atof (nth 1 (nth 0 lst))))
  ) ; progn
); if
(if (= howmany 3)
  (setq pLcol (atof (nth 2 (nth 0 lst))))
  ) ; progn
); if
(if (> dist1 0.0)
(setq pt3 (polar pt2 (+ ang (/ pi 2.0)) (abs dist1)))
(setq pt3 (polar pt2 (- ang (/ pi 2.0)) (abs dist1)))
(command "offset" (abs dist1) obj1 pt3 "")
(if (>= howmany 2)
(vla-put-ConstantWidth (vlax-ename->vla-object (entlast)) pwidst)
(if (= howmany 3)
(vla-put-color (vlax-ename->vla-object (entlast)) plcol) ; note color as a number
) ; end while
(command "erase" obj1 "")
) ; end defun
(AH:multpl)
