Plotting a drawing that is not orinetated N-S
jdavison1
I think I know what you are asking but more details are needed to be sure.
In the mean time, you can rotate a viewport and have the MS work follow.
You can go into a viewport and use the DVIEW, pick objects, TWist to rotate the view of objects in the viewport.
You could also look at UCS you can have as many as you like in modelspace or in layouts including different ucs in multiple viewports remember to use UCS S. UCS OB pick a line then PLAN.
