Hardly a beginner, but here goes a start up question:
Having problems with the selection methods. Cant activate the wp, co, or fence option wile in selection prompt. Have in mind that on another comp it works just fine. I tried tipping the entire words, and _wp, _cp... Had no success :/ so I decided to ask for your input.
Always have bean a great help
Thx :)
Are you talking of selection while inside a command or directly on prompter (without a command active)? For latest case, it may be that isn't supported on your version of AutoCAD (was relatively recently introduced).
I don't think it's supposed to work in a cmd.
To answer you q: I tried both, none work.
1st way
1. type a cmd: select
2. select objects: wp
3. select objects:
2nd way:
1. type a cmd: (let click-started the selection window)
2. specify opposite corner: wp
3. specify opposite corner:
In both cases the wp or others that I tried that were mentioned in the first post don't seem to work.
I's rly bugging me now.
So, this succession of inputs doesn't work on your station?
Command: _COPY
Select objects: _WP
First polygon point:
Please what command !! When posting please explain exactly cmd move select wp ????
Ok, this was more helpful then one would think
Problem solved
Copy -> Wp (before the first pick, works fine)
