nseehafer Posted March 12, 2014 Share Posted March 12, 2014 I recently started using a command called "Flatten" to get objects to zero at the z coordinate but now I am experiencing some problems. Line segments in the y coordinate will show up with just one point instead of the usual three points. Also the flatten command has z set at -1e99. Any idea on what this command is doing to my line appearance? Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 13, 2014 Share Posted March 13, 2014 It will help if you go to Units, and temporarily set your units precision as high as it will go. Sometimes rounding to two or three decimal places, or to say 1/32" leaves little bits of things with a Z axis length smaller than your precision level. Quote Link to comment Share on other sites More sharing options...
