Hi is there anyway to find mass and volume in autocad.
For eg: If i design a jewellery using 3d Autocad or if i import from 3dsmax to autocad can i find the mass and volume of that particular jewel in autocad
Please help
Thanks
Some extra clarifications:
  • Will need to make sure that the items you were looking to list were solid entities, since this is what said command expects.
  • The mass is always calculated with a density of 1.0; so you will need to multiply the volume with actual material's density.
  • If your jewelry is made by more than one material (i.e. metal + gemstone), then will need to call the command for each item to get its volume and multiply it with appropriate density.
You can also retrieve the mass prop info and do stuff with it like above multiply by a weight factor then display answer. Use save to file option
