darris07 Posted December 3, 2008 Posted December 3, 2008 how do i change the viewport scale so that it represents 1/2"=1'-0"? Quote
tzframpton Posted December 3, 2008 Posted December 3, 2008 how do i change the viewport scale so that it represents 1/2"=1'-0"? Click once on the Viewport edge, and then at the Bottom Right of the screen, but above the Command Line window, there's a "VP Scale" option you can select. Or you can do it through the Properties palette. Quote
darris07 Posted December 3, 2008 Author Posted December 3, 2008 WHEN i do it shows an annotation option. i changed the scale there. is that right? Quote
sab423 Posted December 3, 2008 Posted December 3, 2008 Sounds like you were on the model tab and not on another layout tab. From your layout tab select the edge of the Viewport. If you follow StykFace's instructions you should be good. Quote
