andar424 Posted April 9, 2014 Posted April 9, 2014 Has anyone ever seen this?? I get it randomly every once and a while, sometimes when updating sheets in drawings. Quote
JD Mather Posted April 9, 2014 Posted April 9, 2014 I notice that is pointing to the S: drive Are you using Projects (*.ipj) or are you using Vault? If you search C: can you find the file there and copy to the path shown? Quote
andar424 Posted April 9, 2014 Author Posted April 9, 2014 Using .ipj's that are located on the s: drive. Just got home from work and will try your suggestion in the morning. Thanks JD Quote
