Faouweb Posted April 16, 2014 Share Posted April 16, 2014 Hi, I have a lot of lines and I need the Total length, I have them in a separate layer, I have tried with Field and Dataextraction but it is not exactly what I need, or I did not do it exactly. For Field, I can not select all line. Dataextraction takes all lines in the drawing, I need lines that are in the layer. How can I do that? Thank you Quote Link to comment Share on other sites More sharing options...
Organic Posted April 16, 2014 Share Posted April 16, 2014 An excellent lisp here: http://www.lee-mac.com/totallengthandarea.html [tlen.lsp] Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 16, 2014 Share Posted April 16, 2014 Also please note that DATAEXTRACTION command can process either entire drawing or a selection set - use QSELECT or FILTER to build it and input as Previous. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted April 16, 2014 Author Share Posted April 16, 2014 Thank you for your help An excellent lisp here: http://www.lee-mac.com/totallengthandarea.html [tlen.lsp] I used the LISP it's perfect, great tool. Also please note that DATAEXTRACTION command can process either entire drawing or a selection set - use QSELECT or FILTER to build it and input as Previous. Dear MSasu, I have tried what you said but I don't find Previous, can you please explain how to do it, I want to learn it Thank you. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 17, 2014 Share Posted April 17, 2014 Call the QSELECT command and define a filtering rule to suit your case; this will create a selection set with items matching that, those will be highlighted. Now call DATAEXTRACTION and when asked to indicate what to interrogate check Select objects in the current drawing option and press the right locatedl ive selection button; when back in editor input P (for Previous). The previously defined selection set will be highlighted again and used for data extraction. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted April 17, 2014 Author Share Posted April 17, 2014 Thank you MSasu I know how to use it now Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 17, 2014 Share Posted April 17, 2014 You're welcome! Quote Link to comment Share on other sites More sharing options...
