Guest Posted April 17, 2014 Posted April 17, 2014 Hi , i want to make a list box slide (with lisp) like the attach photo. Can any show me an example how to do it ? Quote
Guest Posted April 17, 2014 Posted April 17, 2014 hi ,MSasu .I have seen this post but is not like the example i want Quote
MSasu Posted April 17, 2014 Posted April 17, 2014 Is not identical, but is similar, so you may use it as a starter. Quote
Guest Posted April 17, 2014 Posted April 17, 2014 It is compicated.I need a small example to understand it Quote
Snownut Posted April 17, 2014 Posted April 17, 2014 To get what you are looking for, it will be complicated, best to study the example.....(not a simple application) Quote
BIGAL Posted April 18, 2014 Posted April 18, 2014 If you want super simple then use a mnu with its inbuilt slide function. You cannot change its look but it does support multiple pages. You just have Menu item group that you pick. Also why not Tool palettes. Quote
Guest Posted April 18, 2014 Posted April 18, 2014 Hi Bigal i have a question ***image **TRENCH [TRENCH] [sLD(CGG101,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101") [sLD(CGG102,NATURE)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG102") **PIPES [PIPES] [sLD(SD201,SUBSOIL)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG201") [sLD(SD202,FLUSHOUT)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG202") [sLD(SD203,CATCH)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG203") [sLD(SD204,HOUSE)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG204") [sLD(SD205,STREET)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG205") [sLD(SD206,EASEMENT)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG206") [sLD(SD207,ANCHOR)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG207") all my slides is in a file c:\Symbol library\sld How can i write it ?? Quote
fixo Posted April 18, 2014 Posted April 18, 2014 Go to (F1) Hep file -> Command Reference -> Utilities -> SLIDELIB Quote
Guest Posted April 18, 2014 Posted April 18, 2014 Hi Fixo how to use this ? I canot understand slidelib library [ < slidelist ] dir *.sld /b > mylist slidelib mlib < mylist I try something like this but is not working ***image **TRENCH [TRENCH] [c:\Symbol library\sld (CGG101,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101") or [sLD(c:\Symbol library\sld \CGG101.sld,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101") Quote
Bhull1985 Posted April 22, 2014 Posted April 22, 2014 A lot of examples in the thread that was linked by Msasu This sort of thing, using your own custom paths, images, directories, and actions to be preformed, cannot be simply written for you. You will need to take an honest stab (attempt) to code it yourself, and WHEN you run into a singular issue (error, statement not working, unable to construct statement, etc), then come here and post about it for the quickest results. Not orders but this is how I usually get by so I'm referring you to the same method Quote
BIGAL Posted April 23, 2014 Posted April 23, 2014 The slide library file the slb just needs to live in a location you have defined in your support paths CONFIG FILES "Working Support File Search Path" Add You dont need the path then. I think the space is screwing it up in "Symbol Library" not sure if I posted top menu code ***MENUGROUP=STDS ***POP15 **CADLIB [LIBRARY] [->Stddwgs] [TRENCH]$I=STDS.TRENCH $I=* [PIPES]$I=STDS.PIPES $I=* Quote
Guest Posted April 25, 2014 Posted April 25, 2014 BIGAL I can not understand you sorry .I ask for a specific directory c:\Symbol library\sld Can any one give an example with this ??? Quote
Guest Posted April 25, 2014 Posted April 25, 2014 Ok here we are . I have this list box menu The sld must be the path of slide icons The full path is c:\topocad\sld Don't forget .I have gone to tools -> options and give the path c:\topocad ***image **Symbols [symbol library] [sLD(arrow,Arrow)]^C^C^P(load"symbols");_arrow [sLD(north,North)]]^C^C^P(load"symbols");_north The slide icons is in the sld folder but when i load the menu i can't see the icons if i write this and coppy my slide icons in topocad file only ***image **Symbols [symbol library] [(arrow,Arrow)]^C^C^P(load"symbols");_arrow [(north,North)]]^C^C^P(load"symbols");_north this menu works and see the icons. The problem is that i want to put my slide icons in the file sld. How can i do it ? Quote
BIGAL Posted April 26, 2014 Posted April 26, 2014 As Fixo previously posted Ok bottom left click Start then CMD then c: CD\ Cd topocad\sld dir *.sld /b > mylist slidelib SLD a new file SLD.SLB should now exist should now work, if slidelib does not work look for it in c:\program files\autodesk\Autocad 2013 etc and copy to topocad\SLD Quote
Guest Posted April 26, 2014 Posted April 26, 2014 Hi Bigal .I do all the steps C:\topocad\sld .After that can't find any *.slb file in sld folder?? Quote
Guest Posted April 26, 2014 Posted April 26, 2014 In the cmd after C:\topocad\sld i add dir *.sld /b > mylist. And Create a file with name mylist with no extension in sld folder. Then i add slidelib SLD Quote
BIGAL Posted April 27, 2014 Posted April 27, 2014 I take it could not find SLIDELIB I usually copy it to a shorter directory like my c:\acadtemp so I can find it easy C:\acadtemp\slidelib SLD Use a script to make sld's can do 100+ dwgs in a few minutes. Open dwg1 Z E Z 0.9 mslide dwg1 close N Open dwg2 Z E Z 0.9 mslide dwg1 close N Quote
