hellnback Posted April 24, 2014 Posted April 24, 2014 Hi all, All I want is my grading to NOT put in a radius! From what I can tell this has not been an option since LDD. I just want my square corner I'm targeting an existing surface so I have no idea what the height would be, at said corner, in order to manually draw a featureline. Quote
JerryG Posted April 24, 2014 Posted April 24, 2014 So you dont want a radius around a corner in Plan view? Quote
JerryG Posted April 28, 2014 Posted April 28, 2014 If you create an Alignment using square corners then create a corridor using assemblys as opposed to just using Feature lines I think it will give you what your looking for. You would want the "Basicsideslopecutditch" Assembly so you can specify slope etc. You will need to create a Profile when creating the Corridor which will give you your elevations (that you could change anytime) Quote
hellnback Posted April 28, 2014 Author Posted April 28, 2014 Ended up manually draughting featurelines, was a bit time consuming but gave me the results I needed... and not exactly "dynamic" but nearing the end of the design so hopefully their will be no changes! Quote
