hi
im trying to entmaking lwpolyline, the problem is when set the DXF 10, i actually paste a list rather a dotted pair, any way to fix it?
(defun drawPoly	()
 (setq p nil pl nil)
 (while (setq p (getpoint))
   (setq pl (cons p pl))
 (entmakex (list
      '(0 . "LWPOLYLINE")
      '(100 . "AcDbEntity")
      '(67 . 0)
      '(410 . "Model")
      '(8 . "SG_WALL")
      '(100 . "AcDbPolyline")
      (mapcar '(lambda (a) (append (cons 10 a))) pl)
(entmakex (append (list '(0 . "LWPOLYLINE")
                         '(67 . 0)
                         (cons 410 (getvar 'ctab))
                         '(8 . "SG_WALL")
                         '(70 . 1)
                         (cons 90 (length pl))
                   (mapcar '(lambda (a)  (cons 10 a)) pl)
Edited by Tharwat
No need to function append
                         '(67 . 0)
                         '(8 . "SG_WALL")
                         '(70 . 1)
Hello Tharwat , its about the same as what i did?
(cons 10 a) will return a list rather a dotted pair !?
Really ?
Did your routine work for you ?
There is no need to have a dotted pair because I appended the list of points to the entmakex function .
A dotted pair will only be returned if the second argument passed to cons is an atom.
If the second argument is a list, cons will push the first argument onto the front of the list.
Observe:
_$ (cons "a" "b")
("a" . "b")
_$ (cons 1 2)
(1 . 2)
_$ (cons '(1 2 3) 2)
((1 2 3) . 2)
_$ (cons 1 '(1 2 3))
(1 1 2 3)
Observe:
_$ (cons "a" "b")
("a" . "b")
_$ (cons 1 2)
(1 . 2)
((1 2 3) . 2)
(1 1 2 3)
thats what i said , since the point coordinate are formed as a list, cons will make a list, so how come entmakex can accept list that is not dotted pair?
All that due to the function append that I used in my previous post whilst you insist on dotted pairs . :D
DXF groups with list values will not form dotted pairs due to the behaviour described above - the only requirement is that the DXF group number is the 'car' element and the DXF value is the 'cdr' element.
sorry , you right like most of the time ;)
thanks LEE , i don't remember anywhere reading that the dotted pair is not a DXF mandatory data , good to know...
