Creating Point Lists From Local Variables..?
Hi,
Just trying to get my head around the process to define points/co-ordinates base on the DIMSCALE, so I have the follow 2 variations of code - the difference between the two is coloured red.
(DEFUN C:test ( / xcoord ycoord bpt )
(setq xcoord (* (getvar "dimscale") 424))
(setq ycoord (* (getvar "dimscale") 96))
[color="red"](setq bpt (list xcoord ycoord))[/color]
(command "line" bpt)
[color="red"](setq bpt '(xcoord ycoord))[/color]
My question is, why does the first code work, but the second fails? No error message is given. Where am I going wrong with the list quoting?
Thanks a lot for any help.
I've run across this same thing before. I don't know much, but here's what I do know:
After removing the declared variables (DEFUN C:test (), and banging (!bpt)...
The first case returns: (424.0 96.0), the second: (XCOORD YCOORD).
So I'd guess maybe they're both ways to create a list, the first is designed for when you need an integer returned, the second way is for if your code needs a string returned? I'm interested to know the real answer, good luck! :P
Good point LosGirk. Perhaps quoting the variables adds the variables to the list, rather than the values of the variables.
Thanks for the reply.
That's exactly how it works....
Understood (now). Thanks a lot for the input guys.
Great article Lee, thanks also for providing the link Marko.
Thank you lamensterms - I'm glad that the explanation was clear :thumbsup:
