Does anyone have a lisp solution to joint the equally spaced points a long two separate lines opposite eachother. The lines may be curved and may not be parallel.
The idea is that the program would work along two lines in a chosen direction and everytime it hits a point on the lines it joins them with a polyline.
I don't know if this is clear
Many thanks
  • Replies 26
  • ymg3
    13
  • churchntj
    12
  • BIGAL
    1
  • Bhull1985
    1
Posted Images
A way using lisp, not code use divide create points then join the points if say 5 pts per line then 1-6 2-7 3-8 4-9 5-10. Some one may have have to go and do work now.
So I think I understand your post. In my situation the points are already there; I have already used > and I would like Autocad to join the points along the lines working along them from one end. So what I am looking for doesn't need this step.
I have done MATLAB coding so have a general understanding of coding but dont know LISP. Does anyone have any ideas of how to put some code together to achieve this?
Thanks
Edited by churchntj
Misunderstood the post above
churchntj,
List the vertices of both polylines, then entmakex the lines taking
first endpoint in list1 and second from list2
(defun c:test (/ a b lst1 lst2)
   ;;; listpol   by Gille Chanteau                                            ;
   ;;; Returns the vertices list of any type of polyline (WCS coordinates)    ;
   ;;; Argument                                                               ;
   ;;; en, a polyline (ename or vla-object)                                   ;
   (defun listpol (en / i p l)
      (setq i (if (vlax-curve-IsClosed en)
 	         (vlax-curve-getEndParam en)
         (+ (vlax-curve-getEndParam en) 1)
      (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
        (setq l (cons (trans p 0 1 ) l))
   (setq lst1 (listpol (car (entsel "\Select First Polyline: ")))
  lst2 (listpol (car (entsel "\Select Second Polyline: ")))
   (mapcar '(lambda (a b) (entmakex (list (cons 0  "LINE")
				   (cons 10 a)
				   (cons 11 b)
      ) lst1 lst2)
Well done ymg, your use of mapcar and lambda in this routine are fairly self-explinatory and help in my understanding of the functions. For that I am very gracious.
Thank you!
bhull,
Thanks! for the kind words. :)
ymg
Thank you very much that looks great.
Am not currently on a PC with Autocad. Would this LISP work with points along two splines, poylines, arcs etc or combinations?
Thanks.
churchntj,
It will work with arc.
With spline whatever vertex are defined by the vlax-curve function
will be joined. (these are different than the control point used to create the spline)
So we may say it works.
ymg
Hey There,
Ok, back at work and have tried out the lisp. I'm not sure I was very clear in expressing what I was looking for.
So actually I am looking for points that have been placed on a line, polyline, spline or arc, to joint with points placed on another line. Also ideally the points would be joined by a polyline not a line. It looks the same as the image that you showed except those points are joined are put there and are not vertices of the polyline.
I would include an attachment but am having issues uploading anything to the forum.
churchntj,
The following requires Express Tools installed on your system.
Polylines are used as fence to select the points.
(defun c:joinpt (/ a b en1 en2 enl1 enl2 flt lst1 lst2 p)
  ;; getfencesel        by ymg                                               ;
  ;; Arguments:  en,  Linear Entity Name (Polylines, Arc, Ellipse etc.)      ;
  ;;            flt,  A valid Entity filer Ex: '((0 . "3DFACE"))  or nil     ;
  ;;   Returns: A Selection Set of Entities touching the selecting entity.   ;
  ;;  Requires: Express Tools                                                ;
  (defun getfencesel (en flt / fe px ss)
     (acet-ss-zoom-extents (setq ss (ssadd en)))
     (setq px (* 0.75 (acet-geom-pixel-unit))
           fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en (/ px 2.0)))
           ss (if flt (ssget "_F" fe flt) (ssget "_F" fe))
  ;; mk_lwp    by Alan J Thompson                                            ;
  ;; Argument: pl, A list of points (2d or 3d)                               ;
  ;; Create an LWPolyline at Elevation 0, on Current Layer.                  ;
  ;; Return: Polyline Object                                                 ;
  (defun mk_lwp (pl)
     (vlax-ename->vla-object
        (entmakex
          (append (list '(0 . "LWPOLYLINE")
                        '(100 . "AcDbEntity")
                        '(100 . "AcDbPolyline")
                         (cons 90 (length pl))
                        '(70 . 0)
                  (mapcar '(lambda (p) (cons 10 (trans (list (car p) (cadr p)) 1 0))) pl)
  (setq en1 (car (entsel "\nSelect First Polyline: "))
 en2 (car (entsel "\nSelect Second Polyline: "))
 flt '((0 . "POINT"))
       enl1 (acet-ss-to-list (getfencesel en1 flt))
enl2 (acet-ss-to-list (getfencesel en2 flt))
  (setq lst1 nil lst2 nil)
  (foreach e enl1
     (setq lst1 (cons (cdr (assoc 10 (entget e))) lst1))
  (foreach e enl2
     (setq lst2 (cons (cdr (assoc 10 (entget e))) lst2))
  (mapcar '(lambda (a b) (mk_lwp (list a b))) lst1 lst2)
Points are join with LWPOLYLINES with the help of AlanJT's routine
That's great it now works perfectly apart from the fact that I can't seem to make it work with arcs.
churdchntj,
In the image I posted for this version, top polyline has two arcs
and bottom one is a spline.
One problem could be that we are approximating the fence with
straight line segments. Your target is kind of small being points.
So in the case of very tight arc, It could miss.
ymg
I have tried a few times and can't get it to work with either just arcs or arcs within a set of polylines. THis is what my command line does:
(It has occurred to me that, I am working in French AutoCAD, so could this be having an effect? So far I haven't had a problem with this)
Commande: JOINPT
Select Second Polyline: _.zoom
Spécifiez le coin d'une fenêtre, entrez un facteur d'échelle (nX ou nXP) ou
[Tout/Centre/DYnamique/ETendu/Précédent/Echelle/Fenêtre/Objet] : _w
Spécifiez le premier coin: Spécifiez le coin opposé:
Commande: _.zoom
Commande:
churchntj,
Are you sure you got Express Tools Installed ??
You should receive a prompt to Select the First Polyline
then the Another prompt to Select the Second then
Command proceed with drawing the line.
Right Now you are breaking up at (acet-ss-zoom-extents (setq ss (ssadd en)))
which is the very first Express Tools being called.
ymg
ymg3,
Express Tools is Installed and working. The lsp works well with normal polylines.
The two prompts work and it is upon clicking on the second line that the error occurs:
Spécifiez le premier coin: Spécifiez le coin opposé: *Incorrect*
; erreur: Fonction annulée
churchntj,
C'est a ce moment que la fonction "acet-ss-zoom-extents"
est appelée.
Forcément c'est la que le problème se situe.
Autre possibilité si l'étendue de ton dessin est très grande.
Fais un essai en enlevant la première ligne de la fonction (getfencesel)
ymg
churchntj,
Essaye en remplaçant la fonction "getfencesel"
par la suivante:
     (vl-cmdf "_ZOOM" "_O" en "")
No, ca ne marche toujours pas!?
churchntj,
Can you upload your drawing where it does not work.
Save it as release 2010, I don't have 2014
ymg
churchntj,
Are you by any chance using Windows 8,
cause if it is the case some of your command
in Express Tools might not work.
ymg
