I am not on Windows 8 but windows 7. Sadly I am unable to upload my drawing as for some reason I cannot! Could it not be to do with the fact that I am on AutoCAD 2014?
  • Replies 26
  • ymg3
    13
  • churchntj
    12
  • BIGAL
    1
  • Bhull1985
    1
Posted Images
churchntj,
Kerry ran it for me on Autocad 2014 and report that it went well.
So check your Express Tools Installation. Make sure that the path
to express tools is present in OPTIONS -FiLE - Support File Search Path
ymg
Ok well for now it just doesn't seem to be working for arcs but it is working for spline and polyline which is great. No worries.
Just a random one: Do you have a LISP knocking about that will place a point at the extremities of a polyline all polylines selected?
churchntj,
Transform your arc into a polyline with command PEDIT.
For your points at both ends:
(setq en (car(entsel)))
(setq sp (vlax-curve-getstartpoint en)
     ep (vlax-curve-getendpoint en)
(entmakex (list '(0 . "POINT") (cons 10 sp)))
(entmakex (list '(0 . "POINT") (cons 10 ep)))
ymg
Any chance you could complete the code as I can't seem to make it work and don't have a lot of LISP writing experience
churchntj
The first code now work. Thanks
This will add 2 points at the extremity of the two polylines
and then proceed to join all the points.
(defun c:joinpt (/  en1 en2 enl1 enl2 flt lst1 lst2 ep sp)
  ;; getfencesel        by ymg                                               ;
  ;; Arguments:  en,  Linear Entity Name (Polylines, Arc, Ellipse etc.)      ;
  ;;            flt,  A valid Entity filer Ex: '((0 . "3DFACE"))  or nil     ;
  ;;   Returns: A Selection Set of Entities touching the selecting entity.   ;
  ;;  Requires: Express Tools                                                ;
  (defun getfencesel (en flt / fe px ss)
     (acet-ss-zoom-extents (setq ss (ssadd en)))
     (setq px (* 0.75 (acet-geom-pixel-unit))
           fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en (/ px 2.0)))
           ss (if flt (ssget "_F" fe flt) (ssget "_F" fe))
  ;; mk_lwp    by Alan J Thompson                                            ;
  ;; Argument: pl, A list of points (2d or 3d)                               ;
  ;; Create an LWPolyline at Elevation 0, on Current Layer.                  ;
  ;; Return: Polyline Object                                                 ;
  (defun mk_lwp (pl)
     (vlax-ename->vla-object
        (entmakex
          (append (list '(0 . "LWPOLYLINE")
                        '(100 . "AcDbEntity")
                        '(100 . "AcDbPolyline")
                         (cons 90 (length pl))
                        '(70 . 0)
                  (mapcar '(lambda (p) (cons 10 (trans (list (car p) (cadr p)) 1 0))) pl)
  (setq en1 (car (entsel "\nSelect First Polyline: "))
 en2 (car (entsel "\nSelect Second Polyline: "))
  sp (vlax-curve-getstartpoint en1)
         ep (vlax-curve-getendpoint en1)
  (setq sp (vlax-curve-getstartpoint en2)
        ep (vlax-curve-getendpoint en2)
  (setq flt '((0 . "POINT"))
       enl1 (acet-ss-to-list (getfencesel en1 flt))
enl2 (acet-ss-to-list (getfencesel en2 flt))
  (setq lst1 nil lst2 nil)
  (foreach e enl1
     (setq lst1 (cons (cdr (assoc 10 (entget e))) lst1))
  (foreach e enl2
     (setq lst2 (cons (cdr (assoc 10 (entget e))) lst2))
  (mapcar '(lambda (a b) (mk_lwp (list a b))) lst1 lst2)
